I only get a chance to get into the garage once the kids are in bed and a few house hold chores are out of the way, so it’s normally 9 to 10 at night before I start and don't usually pack up 'till 1am and this is the third day so I’m knackered.
In first couple of nights I pulled the bodywork off first to give me some working room, removed all the anti-bling parts and sorted out a couple of little problems. When I was fitting the exhausts I noticed a little bit of discolouration of the CF, so I gave a few taps and found a hollow point, bugger.
So last night I took them off again, drilled out the rivets and pulled them apart. How I wish it was as easy to do as to type! There’s no mention of the swearing, burnt fingers, swarf cuts, minor Stanley knife lacerations or fag smoke in the eyes whilst wielding an electric drill. The packing was burnt away in one can in a localised area (didn’t take a photo) so I’m glad I did it now.
Here’s a pic of the internals.
What do you reckon to this gauze that was wrapped round the perforated pipe?
I was going to wrap a layer of SS wool instead of reusing this. The gauze is very fine and my thoughts are that it may be too fine and being so thin doesn’t protect the packing. Any thoughts?
There isn’t any lining in the CF tubes. See
So I used this heating duct tape (thickish ally foil I liberated from a previous employer a while back thinking that it would come in handy one day).
To line the sleeve.
Like the new number plate?
My thinking is that it might provide some protection to the CF by means of heat reflection and localised dissipation and even if it the stick packs up it’s not going anywhere.
So my questions.
Gauze, SS wool or both?
Tape – a good idea or do you envisage a problem?
How the hell do you get the ends back into the tube (bloody tight fit)?
