Swingarm
Re: Swingarm
What single arm swingarm will fit my 2002 falco
Re: Swingarm
I have no idea if it's possible, but I'd have thought the obvious candidate from the Aprilia range would be a Futura single sided swingarm. Not sure if it's an aesthetic match, and it will need a fair amount of engineering to make it work. There is no SSSA that is a drop-in solution. Whatever you do will involve a lot of machining and fabrication and the result will be a bike that is heavier, won't handle as well and will probably be a bit of a pig's ear.
Re: Swingarm
So that's a good idea then :D :D :Dmangocrazy wrote: ↑Sat Nov 21, 2020 7:03 pmI have no idea if it's possible, but I'd have thought the obvious candidate from the Aprilia range would be a Futura single sided swingarm. Not sure if it's an aesthetic match, and it will need a fair amount of engineering to make it work. There is no SSSA that is a drop-in solution. Whatever you do will involve a lot of machining and fabrication and the result will be a bike that is heavier, won't handle as well and will probably be a bit of a pig's ear.
