Suzuki GN 250 - indicators going insane
Wildebeest
Main bike: Suzuki GN 250
#1 Post by Wildebeest » Sat Jun 13, 2020 6:04 pm
Hi there
This is my second post - first one being the greeting thingy - and, yeah... I seem to have a bit of an issue.
My indicators are going haywire. My bike was in storage for a year, so I've done the standard back on the road things: recharged the battery, exchanged oil and filters etc.
I've noticed that both my left and right hand side indicators are flashing way too fast. All the bulbs are brand new, and are both front and back were lighting up. My friend told me that it is probably caused by a busted relay, so I ordered it online. I'm still waiting for it. There is another development unfortunately, namely my back right indicator refuses to work. I have put the bulb in another indicator, and it is fine. I have also cleaned the connection (mushroom thing inside the indicator itself) as well, but still nothing. All the wires seem to be intact.
My question is: Is it possible for a busted relay to both cause the indicators to go crazy fast, and also preventing one of the lights to work.
Mike
Re: Suzuki GN 250 - indicators going insane
#2 Post by BikerGran » Sat Jun 13, 2020 8:04 pm
In my experience, absolutely anything is possible with indicators. It probably is the relay but if that doesn't fix it, it could be an earthing problem. Check the nut/bolt/whatever that holds the indicators to the frame cos that's where they earth. Don't just check, if they're reasonably easy to reach undo and clean up around them and do up again.
Wildebeest
#3 Post by Wildebeest » Sat Jun 13, 2020 8:12 pm
I really do hope it is just the relay. It would be an easy fix for me than. I'm not too skilled.
#4 Post by BikerGran » Sat Jun 13, 2020 8:20 pm
The only way to learn is to have a go! I'm not skilled, and I don't ride any more because of age and arthritis, but when I had bikes I did most of my own maintenance. I had biking friends I could go to for advice and help if necessary. Have you not been riding long?
#5 Post by mangocrazy » Sat Jun 13, 2020 11:05 pm
I'd definitely check out all the earth points and connections in the indicator circuit. A bad earth is simply the number one electrical problem with older bikes (and cars). Clean up all the bullet connectors and all the bulb holders and check where any wires are connected to earth.
Wildebeest
#6 Post by Wildebeest » Sun Jun 14, 2020 12:59 pm
@BikerGran
I had a bit of a break from riding due to cash problems. My girl was sitting in my mate's gaf. I know the mechanical part of maintenance, but electrics always seemed like black magic for me.
@mangocrazy
Bullet connectors checked and cleaned up. It's like you're saying, it probably is bad earth. I have a new relay coming from wemoto anyway, since I ordered it last thursday. I really hope it will be just that. Wires do not like my touch.
Wildebeest
#7 Post by Wildebeest » Mon Jun 15, 2020 1:41 pm
So relay has been exchanged. That helped with flashing too fast,but rear indicator was still dead.
So I have checked all the wires. There were three points, that were not secured enough, so I used my thermal shrink connectors to put them back in order. Still no change.
And then I looked under the seat... That indicator slipped out of the plug... :smt011
Why didn't I check that in the first place? I didn't know that there was a plug
katie1
Main bike: S1000RR, 1290 SDGT
#8 Post by katie1 » Mon Jun 15, 2020 4:30 pm
Love those 'kill switch' moments :smt003
#9 Post by BikerGran » Mon Jun 15, 2020 8:06 pm
Ah, I forgot to say the most important thing that I usually start with
"Always check the simplest things first" :smt021
Sorry about that!
At least it's not difficult to fix and not going to cost you money!
#10 Post by mangocrazy » Mon Jun 15, 2020 9:54 pm
Glad you got there in the end. We've all had those "d'uh" moments... :smt003
Wildebeest
#11 Post by Wildebeest » Tue Jun 16, 2020 2:47 am
In my case it was more like Homer Simpson style "D'OH!"
Join me in the next episode of my less than amazing adventures in the world of amateur motorcycle maintenance, when I will try to exchange an old rear brake switch, since the current one is not turning off properly. :smt003
katie1
#12 Post by katie1 » Tue Jun 16, 2020 10:44 am
ooh, good luck. This may be your friend:
https://www.mandp.co.uk/products/wurth- ... 0ml-692808
#13 Post by fatboy » Tue Jun 16, 2020 3:45 pm
ACF 50 is fantastic at rejuvenating electrical components
Some of its applications are listed as ' avionic components, micro switches PC boards rheostats/ circuit boards '
Wildebeest
#14 Post by Wildebeest » Tue Jun 16, 2020 5:35 pm
Ummm... Yeah... Well...
I just binned the old switch, and put a new one in. After trying to stab myself with the guide spring.
I didn't know, that they are hard-wired into the electric system.
#15 Post by fatboy » Wed Jun 17, 2020 1:54 pm
It's all a learning curve !
Long nosed pliers are an essential when playing with fiddly springs like that, injuring digits is not fun.
A multi meter is a must for electrical problems, you can trace where you have power and where you don't, if you don't have power is it a blown fuse ?
Wouldn't be the first time someone spent hours tracing circuits, checking switches only to find they forgot to put the fuse back in
