Back to the top ....
If you're struggling to do anything on the forum or if you've got a suggestion for a new feature you'd like to see, post it here.
XJR Jason
#1 Post by XJR Jason » Tue Dec 31, 2019 2:12 pm
Would it be possible to have a 'back to the top' button?
I've found myself scrolling back up to the forum button, to the see new posts.
Re: Back to the top ....
#2 Post by mangocrazy » Tue Dec 31, 2019 10:01 pm
There is the 'Jump To' button at the bottom of the topic, where you can access any part of the forum. But it would be good to have a user-specific 'Posts since you last logged on' button somewhere. Is that what you were meaning?
XJR Jason
#3 Post by XJR Jason » Thu Jan 02, 2020 9:42 am
I guess what I was looking for was a 'back to Forums' (or as you put, back to unread posts) as that then shows all topic subjects and if any have had new posts since last seen.
The jump to, and return to, only go one stage back.
But there are only so many buttons/short cuts that can be added etc.
#4 Post by mangocrazy » Thu Jan 02, 2020 9:59 am
I'm sure Ben will be along shortly, and he'll know if what you want is feasible. I'm not quite brave enough to start cutting and shutting the new forum layout yet... :smt003
#5 Post by BikerGran » Fri Jan 03, 2020 12:08 pm
If you go down the page a bit further from the 'back to (whatever) form' there's a link that just says 'Forums' - I use that, straight back to the top.
#6 Post by Ben » Fri Jan 03, 2020 1:14 pm
Cool ok. I think you're after a goto link, where when you click it, it scrolls back to the top of the page?
See the little grey arrow on the bottom right of every post? That'll do it.
XJR Jason
#7 Post by XJR Jason » Wed Jan 08, 2020 3:45 pm
Well that's far too small :smt023
Yup that's the one
