Millie power from falco engine
#16 Post by mangocrazy » Tue Apr 15, 2014 8:18 am
Yellowperil wrote:IJust a quick query, any idea what Black Magic cossworth cast upon the SP the give it more power than the same year milie?
The SPs were completely different to the standard Mille, and very little is/was interchangeable. This is true for suspension as well as engine. The SPs are also as rare as hen's teeth.
Obiwan Kenobi
#17 Post by Obiwan Kenobi » Tue Apr 15, 2014 9:17 am
You say you want more bhp, but don't want more straight line power and only seen 140+ once.....
So why do you need more power?
If you're not going drag racing, best spend on any bike, as has been said, is to sort out your handling. Static sag to start with, then tweak your suspension settings one at a time, or spend money of fork set-up for your weight (with riding gear on) and a better shock, properly set up.
More acceleration is available pretty much for free with the 15t sprocket option too.
These are not the Droids you're looking for...
Yellowperil
#18 Post by Yellowperil » Tue Apr 15, 2014 2:18 pm
Yes only just under 150 because that's all I seem to be able to get out of her, funny you might mention drag racing, I'm actually participating in NSA sprinting this year but not on the falco, on a 1986 VFR400 it's been light weighted so far and is pretty good for its class!
However the falco I would like to have a bit more power, as I mentioned before it all ready handles well, or at least I like the way it handles and if anything I think it handles better than it goes.
The 01+ rsv heads and ex system seem to be the way I'm going to go as it's accessible and a reduction in final drive gear ratio seems a valid possability too!
#19 Post by Aladinsaneuk » Tue Apr 15, 2014 5:14 pm
Out of pure interest - what have you already done to the bike?
I think that would be a good starting point....
Exhausts?
Airbox?
Chip?
Yellowperil
#20 Post by Yellowperil » Tue Apr 15, 2014 11:03 pm
Forza chip, fuel cans no baffles that's it as far as performance tweeks go.
Fully serviced last month new plugs, air filter 15/50 fully synth silkolean!
Fully derestricted, air box snorkel removed, wire on ecu cut
23,000 miles on the clock
Makes 102bhp at rear wheel, approx 116 at crank.
Dyno'd last month :)
#21 Post by Aladinsaneuk » Wed Apr 16, 2014 5:10 am
why remove the snorkel?
consider one of the airbox mods
consider a mid pipe mod
#22 Post by blinkey501 » Wed Apr 16, 2014 5:47 am
Yellowperil wrote:Forza chip, fuel cans no baffles that's it as far as performance tweeks go.
Think I might put my bike back to standard.
It made 106 BHP at the rear wheel before I started to fit an air box and cans :smt017
#23 Post by D-Rider » Wed Apr 16, 2014 8:17 am
Different dynos - you can't compare.
Pete - I think the "snorkel remove" is more likely the restrictor plate under the air filter - I guess the tube on that can look a bit like a snorkel (probably moreso than the bit we tend to refer to as the snorkel)
Yellowperil
#24 Post by Yellowperil » Wed Apr 16, 2014 1:15 pm
Yes quite right it's the bit the air filter sits on, it was removed prior to my ownership.
So will the 2nd gen rsv factory heads fit on my falco engine?
#25 Post by D-Rider » Wed Apr 16, 2014 2:39 pm
Yellowperil wrote:Yes quite right it's the bit the air filter sits on, it was removed prior to my ownership.
I believe they will
Don't forget that Gen2 bikes have a 4 stud exhaust mounting rather than the 3 stud of the Gen1 and Falco
Yellowperil
#26 Post by Yellowperil » Wed Apr 16, 2014 4:17 pm
The stud issue ain't to bad providing the diameters of the pipes are the same, I can get new flanges made as I'd like to keep the twin cans, I've read that the 2nd gen need a cam sensor installing on the front head to run on the 1st gen bikes, also are the falco Throttle bodies large enough or will bigger ones need sourcing?
Firestarter
Twisted Firestarter
#27 Post by Firestarter » Wed Apr 16, 2014 4:42 pm
Two words that haven't been mentioned...
BIG BORE
#28 Post by D-Rider » Wed Apr 16, 2014 5:22 pm
Firestarter wrote:Two words that haven't been mentioned...
BIG BORE
He sure is ..... with his endless tales of Green Flag recovery
.... oh, and you're not technically correct .... someone mentioned this on page1 of the thread ....
D-Rider wrote:....... Blah blah blah ..........
If you really need more power, talk to Griff about one of his 1060cc big bore kits.
#29 Post by Aladinsaneuk » Wed Apr 16, 2014 8:50 pm
i am going to say it so...
I am not convinced by the forza off the shelf chips....
i would look at an air box mod, and possibly a mid pipe mod - then fit a gabro chip made to that spec
#30 Post by D-Rider » Wed Apr 16, 2014 9:06 pm
I can't say as I've never tried a Forza but I can say Gabro chips are the dogs.
So much so that I can't think of any good reason to try anything else.
