Swingarm, Suspension Linkage, Wheel & Steering Bearings
Cheaper supplier.
http://www.wychbearings.co.uk/hk1812_skf.html
£24.98 for six bearings including vat delivery.
Yes definitely.fatboy wrote:Would it be fair to assume the original type are the preferred type ?
We had a chap on the forum some time back that was a bit of a bearing expert.
What I gathered is that the OEM full compliment bearings are better for low-speed, high-load applications whereas the caged variety are better for lower loaded high rotation speed applications.
The difficulty is in finding the full compliment bearings.
I guess if you can't then a new set of caged bearings are probably better than a knackered full-compliment set but you would need to keep a close eye on them to check all is well.
(Note: This is not my recommendation - if you go that way you do so at your own risk!)
Re: Swingarm, Suspension Linkage, Wheel & Steering Beari
The SKF61904 bearings in the swingarm pivot point. Are they sealed or open bearing Andy?D-Rider wrote:Swingarm & Suspension Linkage:
... just in case anyone needs to know what bearings are fitted to the swinger so you can source them somewhere cheaper than your Aprilia dealer, I've just replaced the bearings in the Mille swinger that I'm fitting.
The bearings used in the Falco and Mille swingers and linkages are the same.
Swingarm:
The pair of ball races (#1 in the picture) are SKF 61904
The big roller bearing (#11 in the picture) is a Torrington HK3026
Linkage:
The roller bearings for the linkage {2 in the swinger and 4 in the dog bone} (#2 in the picture above) are Torrington HK1812V. These are "full compliment" bearings - packed with rollers and no cage and are better for high load, low speed applications ... and are hard to source .... I couldn't get them and have fitted some caged rollers. I'll keep my eye on them and see how they do.
UPDATE: Shootmyscoot has found a source of the correct linkage bearings:Wheel Bearings (Brembo wheels):shootmyscoot wrote: Torrington HK1812V.
If any one needs them they can be got from Motion Industries
Address:Telephone: 0161 705 1237
- Motion Industries,
Unit 2,
Bracken Trade Park,
Dumers Lane,
Bury,
Lancashire,
BL9 9PE
oh they are 4 squids each
sms
Front Wheels Bearings {2 required} (#11 in the picture above) are SKF 6005-2RS1/C3
Front Wheel Seals {2 required} (#10 in the picture above) are 30x47x7 R21
Rear Wheels Bearings {2 required} (#19 in the picture above) are 6205-2RSR-C3 FAG
Rear Wheel Seal {1 required} (#15 in the picture above) - Sorry don't know this one
Sprocket Carrier Bearings {2 required} (#23 in the picture above) are 6006-2RSR-C3 FAG
Sprocket Carrier Seal {1 required} (#21 in the picture above) is 38x52x7 R23
Steering Stem Bearings:
Steering Stem Bearings {2 required} (#1 in the picture above) SF07A22PX1 NTN
Many thanks.
- Firestarter
- Twisted Firestarter
Re:
Has anyone got a good source for these? Have found the bearings at good prices from a number of sources (simplybearings and others), but the gasket rings I'm struggling with (£20+ each against the AP number!)Aladinsaneuk wrote: ↑Wed Jan 04, 2012 6:19 amcourtesy of oliver - go-modem-go:
- Front wheel (OZ or Brembo, same): Ball bearing SKF IT type 6005-2RSH/C3 25x47x12 (AP8110094) x2, Gasket rings Freudenberg Simrit IT 30x47x7 BASL 72NBR902 (AP8125841) x2, Snap ring DIN 472 Seeger-Orbis IN J047x1,75 d47 (AP 8125842) x1
- Rear wheel (OZ or Brembo, same): Ball bearing SKF BG type 6205-2RSH/C3 25x52x15 (AP8110093) x2, Gasket Ring Freudenberg Simrit CZ 38x52x7 BASL 72NBR902 (AP8125838) x1, Snap ring DIN472 Seeger-Orbis DE 52x2.00 d52 (AP8125839) x1,
- Sprocket carrier: Ball bearing SKF type 6006 2RSH/C3 30x55x13 (AP8110081) x2, Gasket Ring Freudenberg Simrit CZ 38x52x7 BASL 72NBR902 (AP8121213) x1, Inside circlip d55 DIN472 052x2.00 (AP8121212) x1
Thanks
Mark
Re: Swingarm, Suspension Linkage, Wheel & Steering Bearings
I'm guessing that 'gasket ring' translates to 'oil seal' in most dialects of English, doesn''t it? Certainly the measurements are what you'd expect from an oil seal. I'd plug the dimensions of the 'gasket rings' into an oil seal search at a site like simplybearings and see what pops out.
- Firestarter
Ta, already ordered some from BearingKing, just waiting for them to check they're right
Next, the fun part of getting the bearings out!
In my experience they don't come out without a fight (or at least some persuasion). However it does help if you have the right kit, chief of which is a blind bearing puller. And a heat source (blowtorch). This is my post from 2013 on how I removed the bearing from my swingarm:
viewtopic.php?f=20&t=10156&hilit=swinga ... s&start=15
- Firestarter
Gave up after about an hour earlier, figured something was going to get damaged by trying to drift them out with a punch, while it might be possible I'd rather not trash anything in haste, especially as the new bearings haven't arrived yet anyway. Only tried with boiling water, not a heat gun so far.
Blind puller/slide hammer on order... we shall see how we get on later in the week
You really do need decent amounts of heat, plus the puller. Trying to drift them out cold is an exercise in futility and won't end well. I'd use a propane gas torch (the sort plumbers use) in preference to a hot air gun - the heat is applied more accurately and there's more of it.
- Firestarter
So, all the wheel and carrier bearings done without too much issue.
Heat - paint stripper did the job. Wasn't needed in all cases, but helped with a couple which were stuck in.
Bearing puller - waste of time. Couldn't get it to engage properly, I think the puller fittings weren't the right size (the one down was max size at the bearing size but I think was slightly too small, the one above started at that size but was slightly too big to go through) and just dug in to the alloy tube anyway, so didn't sit behind the bearing ring. In the end the favourite was a screwdriver, which I ground the end down to both square the sides off to make them parallel (as it was just pushing off the alloy tube when flared) and to flatten the end a bit so it wasn't "sharp".
Lastly, the sprocket carrier was interesting without a press. As there are two bearings which are stacked (with a spacer between them) I had to use both old bearings to drive in the new one without putting pressure on the centre ring, pull out the old bearings (with the bearing puller which worked fine between two bearings) then install the other new bearing with spacer until it just touched the 1st new bearing. Would anyone else have done anything different?
