Chabby wrote:The seal number is SU 28 – 20.5 – 4.2 – DE – EPDM – DK 105
I assume the numbers in bold are the outside diameter, inside diameter and depth respectively. EPDM is the material (necessary for clutch fluid).
The company which supplied them is Fluidpower at the address below.
P.S. The new seal has been fitted and works fine. It cost £2.10
Unit 2 Kellaw Road
Yarm Road Business Park
Darlington, Co Durham DL1 4YA
United Kingdom
Phone 01325 282732
Fax : 01325 381815
Clutch Slave Seal
Clutch Slave Seal
An alternative to Aprilia's (pricey) clutch slave seal has been sourced:
Its possible to do a quick repair if anyone gets stuck for this part, my seal started leaking at 10k I stripped the cylinder cleaned out all the muck removed the seal carefully and applied a small amount of packing using plumbers tape in the grove..don't over do it..
The result was very good and despite getting a new seal I never did fit it
sold the bike with over 35k ish millage never leaked again.
Always expect the unexpected
New source found at a better price:
Tonyunn wrote:Did the slave seal last night, took about 75 minutes and it seems fine, I will test properly at the weekend.
Anyway I thought I would post the details of the seal etc. for future reference.
Fluid Power
Tel 01325 282732
e-mail sales@fpe-ltd.co.uk
www.fpe-ltd.co.uk
Part number SU28-20.5-4.2-DEEPDM-DK105
cost £2.50
after delivery and Vat it comes to £7.38
Aprila Clutch Slave Cylinder
Seal Masters have this item available.
Contact Clive
cm-sealmasters@hotmail.co.uk
http://www.sealmasters.co.uk/custserv.htm
APPROX £3 EACH.
Fluid Power seem to have realized that their is a demand from bikers for the item. They quoted £30 each via their Irish agent??????????
Enjoy
Contact Clive
APPROX £3 EACH.
Enjoy
