Where can I plug into the ignition circuit?
Posted: Thu Mar 05, 2009 11:17 pm
by dyzio
I'm planing to fit heated grips and a cigarette lighter socket (GPS). I don't want to wire them straight to the battery so I was thinking about wiring an extra relay and plug that into the ignition circuit so that they automatically switch off when I take the key out.
Any ideas?
Dyzio
Posted: Fri Mar 06, 2009 1:12 am
Seem to remember I picked up a switched power feed from the fuse box on the RHS of the front fairing. I must have some info somewhere. If I find it, I'll let you know.
Posted: Fri Dec 11, 2009 6:00 pm
by crewmanchris
D-Rider wrote:Seem to remember I picked up a switched power feed from the fuse box on the RHS of the front fairing. I must have some info somewhere. If I find it, I'll let you know.
Hi there just wondered if you found this - just about to wire in some hot grips and this could help!
Posted: Fri Dec 11, 2009 6:07 pm
by joecrx
would be handy for me to , im going to fit a gps
Posted: Fri Dec 11, 2009 6:25 pm
off the parking light would make sense i think
Posted: Fri Dec 11, 2009 8:42 pm
Sure Andy will come up with a quick answer, so can I just say welcome to the site Chris.
:smt006
Posted: Fri Dec 11, 2009 9:18 pm
I replied to the PM .... but I can't remember exactly where I took the feed from - I'll have to take a look.
Sorry
Posted: Sat Dec 12, 2009 1:35 am
OK - I've investigated - I've found out where I took the power feed from - I've taken some pictures - I've drawn some circuit diagrams .... but I'm too knackered to post it all up now ..... so information to be revealed tomorrow.
Posted: Sat Dec 12, 2009 2:46 pm
by joecrx
iv no patiance :smt005
Posted: Sun Dec 13, 2009 8:19 pm
by FlyingKiwi
oh oh I know this one :smt003
I have a little box :smt003 :smt003
It's tucked under the nearside side panel. 3 or 4 terminals are wired and fused to battery via a solenoid which is attached to tail light circuit so the power comes on and off with key. To this I have heated grips, and Autocom. 2 more terminals are wired and fused direct to battery for Cig lighter (under seat cowl) and Zumo sat nav.
:smt020
Posted: Thu Dec 31, 2009 11:47 am
Sorry it's taken so long but there's now a "sticky" containing a description of this in the Aprilia Technical section (above):
https://www.ridersite.com/viewtopic.php?t=5798
