Grease
Posted: Wed Jan 31, 2007 8:40 pm
by johnl
Doing a bit of maintenance and found a white grease on the rear of the brake pads. It was also on the spark plugs which were very easy to remove. I know its not marine grease, but it is really good stuff, anyone know what it maybe ??
Johnr
Re: Grease
Posted: Wed Jan 31, 2007 8:44 pm
by fastasfcuk
johnl wrote:Doing a bit of maintenance and found a white grease on the rear of the brake pads. It was also on the spark plugs which were very easy to remove. I know its not marine grease, but it is really good stuff, anyone know what it maybe ??
Johnr
got to be something similar to copper slip other than that johnl i do'nt know
Posted: Wed Jan 31, 2007 10:53 pm
White? Sounds like Lithium grease. Could be donkey spunk of course, but Lithium grease would be more likely.
Posted: Wed Jan 31, 2007 11:33 pm
Can I be the John Revolting character?
Posted: Wed Jan 31, 2007 11:38 pm
why do i fear a sudden rash of "Pink Ladies" all singing about "Sheila's Wheels" and calling themselves "Frenchie...."
Posted: Wed Jan 31, 2007 11:40 pm
I've got an aerosol of the stuff, but I'm away with work and can't remember anything about it, other than it's in a blue can
. I'll take a look at the weekend, assuming you haven't got an answer by then
Posted: Thu Feb 01, 2007 9:10 am
by Falcoholic
Bloomin LARD ah tell ye!
LARD!!
Posted: Thu Feb 01, 2007 9:22 am
I'm trying to piece this thread together ....
... think I've got it ....
Firestarter dresses in pink, calls himself Sheila and has got his 'aerosol' full of lard and donkey spunk .....
.... what forum did I log on to ??
CONFUSED
Posted: Thu Feb 01, 2007 11:33 am
From what I understand you could have just made a slip when selecting from your favourites list
Posted: Thu Feb 01, 2007 12:29 pm
by fastasfcuk
Firestarter wrote:I've got an aerosol of the stuff, but I'm away with work and can't remember anything about it, other than it's in a blue can
ceramic.
Posted: Thu Feb 01, 2007 4:25 pm
by Thumper
Sounds like lithium grease commonly known as "white grease"
It's an excellent corrosion inhibitor and resists water penetration comes in aerosols or solid form great on washing machine bearings.
I use it on wheel spindles or as a general assembly grease, it has a high melting point but 1 wouldn't use it on brake pads or pins.
http://shopping.lycos.co.uk/search/white_grease.html
Posted: Thu Feb 01, 2007 4:57 pm
by johnl
Posted: Thu Feb 01, 2007 6:19 pm
D-Rider wrote:I'm trying to piece this thread together ....
CONFUSED
I don't call myself Sheila
Posted: Thu Feb 01, 2007 8:30 pm
by fastasfcuk
i've used this ceramic grease on my chain for a couple of years now and find it brilliant, you dont get any over your nice clean wheels or rear end.
Posted: Fri Feb 02, 2007 3:29 pm
by Fausto
Fastasfcuk - I'm interested in this application. How long does it last? Does it clean off? Does it look a mess on the chain ?
More details pleeease.....
