this week ends fettle - Bars moved
Posted: Sun Jun 22, 2008 8:41 pm
Just back from some exhaustive post fettle checks - well, I had to ride a few miles to make sure that all was ok :)
I have moved my handle bars above the tripe yoke
For some time now I have had pain in my back - nothing to do with the bike, just a long time nursing knackers backs!
quite straight forward really, but thought I would post up with a few pointes
My falco has braided steel hoses on both clutch and brake btw
I used a rear paddock stand and a front yoke stand and got the bike up in the air - I also made sue I had a suitable fulcrum point near the front wheel and a long piece of wood to use as a lever
You need a 14mm allen key or socket to undo the central lock nut, then unclamp the top triple yoke and the bars them selves - do not forget to undo the locking bolts! - pop them safely to one side, though we will not need them again for this job
Once they are off, you need to slacken the lower triple clamp and using a friend as weight on the end of the lever move the fork legs up to show 6 rings - you may find it easier to pop the top triple clamp on to ensure you get it right - then tighten up the bottom clamp, and ensure it is tight
My bars with some wiggling came off with all the switches etc still attached - you may need to undo stuff, and possibly reroute things - I did not need to - but just double check...
Now, the fancy part - ensuring that your bars are pinned in place....
take your top triple clamp off and drill a pilot hole through the threaded hole that the lock pin bolts into. Turn the clamp over and drill through the pilot hole - CAREFULLY - you want to just go into the threaded hole - I used a size six drill. Once that is done, I used a correct size tap and continued the thread through the hole so I had a good thread through out.
Reassemble the bars and using a longer bolt - I had a couple lying around with allen key heads tighten down to the thread - but no further, just so there is some resistance and you are certain it is central. I then used a stayloc nut and washer and tightened from the bottom to just to ensure there is no possibility of slackness.
Now you are left with one problem - the brake master cylinder is too proud and hits the fairing. Remove the metal bracket that it is mounted on and then bolt straight into the mounting hole - it is at a slight angle, but clears the fairing easily, and you still have your master cylinder above the brake :)
After a hundred or so miles of extensive road testing, all is good - no back ache
The bikes steering is now a fair bit faster - I will be dropping an ohlins steering damper in over the next week to help with that
Worthwhile doing - I think so
Please just ask if you want any photos posting
Thanks to assorted people who I have asked advice from or who have otherwise assisted me :)
