Sticking gear lever
- back_marker
Sticking gear lever
Took the Falco out for a ride this afternoon but seem to have developed a problem with the gearchange.
I found that when I tried to shift down more than one gear in succession, ie coming up to a roundabout, it would drop down one then I would get no response at all form the shifter. After a little while I realised that the lever wasn't returning to centre after each downshift which was what was causing the problem. Naturally alsorts of horrible thoughts went through my head including return springs and the like but I don't think it was this because I had no problem shifting up, and if I waited a couple of minutes the lever would eventually spring back up. As the journey went on this time became shorter until by the time I reached my destination (some 30-40 miles) i would feel it spring back and tap the bottom of my boot almost straight away but still with a short hesitation.
When I left to come back home the problem seemed to have completely disappeared and was fine all the way back.
That only thing I have done to the bike since I last rode it which can possibly have afected the gears is to adjust the chain but I have checked that and it doesn't seem too tight (not to mention that the problem did not go away with me off the bike and when the chain is slacker because of the suspension not being compressed. I have not ridden the bike for about 3 weeks or so and it has been parked in the garden under a cover so this may also have affected it.
Just wondering if anyone else has ever had anything similar happen to them and maybe knows what if anything I should be checking. I have to use the bike to travel to a course in a week or sos time so I really can't afford for it to let me down when I need to be somewhere.
- Steve McQueen
- Steve McQueen
I would start off by spraying all the pivots and ball joints in the gearshift lever/linkages with lube. Then give it a test. It's possible the pivot is sticky and the ball joints need regular greasing.
If this does the trick you will need to strip the linkages and clean / regrease them - the thin spray lube won't last.
The balljoints just 'pop' apart with a little gentle prying once you have pulled the little retaining springs out.
Good luck.
Good luck.
Yeah, just sounds like a build up of crud. Give it a clean and a re-grease.
- back_marker
pretty much what I was thinking but having looked at it, it is definately the gear shaft that is sticking, not the linkage. Thinking about it I have also had the front sprocket cover off to clean out all the build up of chain lube that was in there - maybe a lump of that has got itself stuck down the side of the shaft or something. May have a look tomorrow.
- Steve McQueen
- Steve McQueen
- Falco9
My thoughts as well, the gear lever has a bronze liner and a combination of old grease and road crap can bind it together quite easily.Nooj wrote:Yeah, just sounds like a build up of crud. Give it a clean and a re-grease.
I can't see how the shaft would stick down on a downshift but not up on an upshift, Like you I think the return spring must be OK. Is the oil seal OK? How was the quality of the gear changes?
If all is OK now it could have been a lump of road grit lodged in the old chain lube maybe??
F9
I've never poked inside the Falco's gear change mechanisms, but my old Honda had two little return springs that pushed the pawl mechanism back into place.
If one of them snapped (and they did, eventually) you could change gears in one direction easily but not the other.
P'haps it's the same on back_marker's Falco?
- back_marker
don't think it's anything to do with the spring(s) as it was springing back eventually either with a little hesitation or a little help. As well as that the problem cleared up on the way home which suggests to me that everything mechanical is sound, it's down to ingress of shite.
Having read another thread, I have just realised there is an O-ring on the shaft, just wondering if that has become dislodged or wedged and that is causing the problem?
Going to dig the spanners out tomorrow anyway and have a good look
- Steve McQueen
- Steve McQueen
Hi all
Sounds exactly like a prob I had a while back, after riding for an hour or so I could'nt get 1st or neutral, stop for 10 mins and all is well for a while then same prob again.
I put mine into a dealers (still in warranty) complaing about knackered gear change but it turns out that it just dries up because it's so close to the exhaust pipe.
So coppergrease the shaft and Bingo gear change back to normal. Until about a year later and same thing again, this time out in the middle of nowhere, so put a few drops of oil (from scotoiler) onto the shaft and away we go.
- back_marker
Sounds good, which part of the shaft are you actually lubricating? The bit that actually goes into th gearbox or the bit just before that which is inside the seal?wavey wrote:Hi all
- Steve McQueen
- Steve McQueen
- back_marker
Resurrecting this old thread, as I've had exactly the same thing happening on my Flamingo Red Falco. While hooning around the Scottish Highlands with a bunch of mates last weekend I became aware of a gear selection problem whenever I needed to bang down the gearbox quickly; i.e when you hit a set of traffic lights after some (ahem) 'spirited' riding.
It's only got about 6.5k miles on the clock so I couldn't believe that there was a problem inside the cases. Today I stripped down the gear linkage and found that the gear change bush that pivots around the LH footrest had been gummed up by some well-meaning soul with Aluminium anti-seize paste. Loads of it. Over time this had turned into the consistency of partially dried out treacle and was making downshifts in particular really claggy.
Once I'd cleaned off all the aluminium goo goo muck and replaced it with 'normal' grease, everything returned to its normal slick self.
Extra points will be awarded to the first person who can correctly answer the question 'which beat combo recorded the tune 'Goo Goo Muck'?
Without Googling the answer, natch...
