front brake light switch
Posted: Sun Nov 18, 2007 9:20 am
by Torn
hi guys, do you know where the front brake light switch plugs into? mine has decided to jam on so want to remove it while i get another ordered? i need to know where it plugs into and how to get to it,
thanks
dave
Posted: Sun Nov 18, 2007 10:20 am
by Okamoto
Hi Torn, I think it plugs into the main harness at the rear of the clocks, so I'm sure to get at it you will have to remove the screen and lower parts of the fairing at least.
Does the switch not remove? going from memory I'm sure it's held on with two very small posi screws, you could take it off and dunk it in some WD overnight to free it off.
Good Luck anyway
