Bleedin' Rear Brake
Posted: Tue Oct 23, 2007 6:32 pm
Having a few problems changing the brake fluid on the rear brake of my falco. No bubbles coming out but brake only just comes on with the pedal all the way down.
My thoughts are that because the bleed nipple is right at the bottom of the caliper along with the brake pipe, the top of the caliper, ie the piston, is full of air that is just sat there while my nice new fluid just gets pumped straight out of the bottom.
If so, my idea is to just take the caliper off and turn it upside down ("just" he says - not looked at it yet but if it's as much of a pain as changing the oil and plugs that would be easier said than done) or is there an easier way that should be staring me in the face.
If not, WTF is the problem?
