DIY Radiator covers...
Posted: Mon May 07, 2007 10:32 am
by falcomunky
Fancied some radiator covers, but wanted something a little different from the usual mesh-type grills.
That and the fact that the sets on Ebay are £70+ made me decide to sort it myself.
The result;
Well
I like em!...
A tenner fer the ally sheet and an hour n a half to 'install'.
'Ay am verry appy'...
Oh, and Ive got a brand new complete set of RSV linkages coming this next week too!
Posted: Mon May 07, 2007 11:01 am
by Gio
Looks very good and just think a lot easier to clean off those chopped up bugs
Posted: Mon May 07, 2007 1:55 pm
by danowat
Where did you get the mesh from?
Posted: Mon May 07, 2007 3:15 pm
by falcomunky
From here;
http://cgi.ebay.co.uk/CT-Racing-Alumini ... dZViewItem
Very fast postage and a good product.
Dont
everybody go n nick me idea though, eh!?
Im also gonna do the air intakes when I get chance/can be arsed to get the fairing off...
Posted: Mon May 07, 2007 4:13 pm
by Hansie
Due the little holes compared to the pitch of them I'm quite sure it blokkes air a lot.....think some 50-60% less fresh air!
If you have the diameter and pitch of the holes you cab calculate the percentage :
(Dia hole x dia hole x 90.69) / (pitch hole x pitch hole) = % air passes true
Say :
D=3mm
pitch=5mm
3x3x90.69/5x5= 33%
So 67% is blokked!
Not a problem if youre watertemp doesnt rise....
Posted: Mon May 07, 2007 4:16 pm
by danowat
The mesh in that link is quite a bit different looking to the stuff you used
Posted: Mon May 07, 2007 4:43 pm
by falcomunky
Oooops!
Try this;
http://cgi.ebay.co.uk/Aluminium-Grille- ... dZViewItem
Its from the same shop, but a little pricier.
Also, Im not too fussed about the airflow reduction, (though I will be checking to see if shes running any hotter than normal), as the ally sheet will also act as a heat sink like in a PC CPU.
Posted: Mon May 07, 2007 6:28 pm
by Pierre
You have to remember the sun only shines 5 days a year over here Hansie.
My temp hovers around 66 on the road and the fans dont kick in till 95 or so. Loads of room to boil water
Posted: Tue May 08, 2007 9:36 am
by gazuk
Linkages - are you getting the dogbone as well, and where are you getting them from as D-Rider seems to have been waiting a while to get his?
Posted: Tue May 08, 2007 12:26 pm
gazuk wrote:Linkages - are you getting the dogbone as well, and where are you getting them from as D-Rider seems to have been waiting a while to get his?
.... yep - still waiting (on order from Speedaway)
Posted: Tue May 08, 2007 3:46 pm
by falcomunky
Re the linkages; Im getting both triangles, dogbone and all the bolts as well. A nice German fella is selling his RSV Ohlins on Ebay and I noticed the links attached so a couple of emails later and they are now on their way to me!
Re the radiator guards; Only the bottom guard is actually bolted in place, (using the two V-piece bolts)! The other two are simply precision-cut, (tin snips
), to wedge between the top and bottom 'rails' and then bent round the outside edge of the rad, (they are also wedged in behind the plastic spine-thing that runs up towards the yokes between the two rads). The fairing, (and wind!), holds em in place!
Closer view; (those are bug splats btw!...
The reason I didnt use the fan-mounting bolts on the backs of each rad, (like the Beowulf set do)? Simple; I ran out of sheet after I tried
this...
Bit
too Mad Max fer me so I took it straight back out!
One has to try these things...
Think I'll get another sheet n do it all properly, this time using the bolts fer extra security and covering the ram-air inlets as well.
Posted: Wed May 09, 2007 12:14 pm
Cheers for that info
being an impatient sod at the best of times, I wandered down to the local motorworld and invested a whole 15 drinking vouchers in some mesh
now cut to fit, and just waiting on DHL to deliver the new belly pan....
I would post pictures, but as danowat's bike is always to clean, I won't
(You think I am joking - i reckon that he must polish every day!)
Posted: Wed May 09, 2007 3:50 pm
by falcomunky
Glad to be of service matey!
(Cleans his bike every day!?!? My teeth dont even get
that treatment...
Posted: Wed May 09, 2007 7:56 pm
by Falken
But you don't ride your teeth.
Posted: Thu May 10, 2007 9:49 pm
by scottyni
diy store mesh for tenner cut to fit simple had it on mine since i got it
10 min job bellypan then stick it with sealant
