Your sprag clutch is part of the main starting mechanism on the Rotax engine that is fitted to your falco.
The main problems that occur is due to a flat or poorly maintained battery.
Your sprag clutch relies on a centrifugal force to engage, to allow the operation of the teeth to grip two surfaces and thus start the engine.
A poorly maintained or flat battery will not allow the engine to spin up quickly, which in turn does not allow the teeth of the sprag to engage correctly or in simple terms "Fling out".
Before you attempt to change your sprag clutch you will need parts.
These is the cheapest place I know where you can buy your parts.
This is a list of where you can buy your parts to do the task yourself. Some the information is courtesy of D Rider.
Griif from Aprilia performance sells the sprag clutches at around the same money as on Ebay. 01827285500.
If griff doesn't have a sprag in clutch.
http://www.ebay.co.uk/itm/BRAND-NEW-APR ... 2580e10312
Stator cover gaskets can be purchased here.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... ink:top:en
The oil filter that is required is here.... Please note.... You need to check if you have a long or short filter.
The oil information is here.
https://www.ridersite.com/viewtopic.php?t=11542
The torque settings can be found here by down loading the manual.
https://www.ridersite.com/viewtopic.php?t=7674
The oil you require can be bought from opie oils. As club members we get a discount, and the company gives first class service.
When you have done the sprag clutch you will need one of these to prevent further problems.
http://www.optimate.co.uk/
Good luck with your sprag clutch change.
Sprag clutch.... Parts required
