Airbox mod...
How would some of you guys like a plate pre cut and drilled ready to take a filter of your choice.
I am sorting one out for myself and also one for Sebastion. I have got the template sorted and the 'correct' hole cutter that allows for the oil seals to be inserted properly. Seb can tell you if it is any good when he gets his. I am estimating around £10 to £15 each which will cover materials and a smidge for my time and effort.
Sorry to hear that, P.paddyz1 wrote:Sorry guys this is turning out to be a nightmare![]()
so I am gonna nip this in the bud now. Maybe it is the material that I am using but I have been on it all night and not even half way there. If I can lay my hands on some decent plastic I will start again.
I will let you know
I'm far from an expert but every time I started doing something from plastic it was turning into a nightmare (if not dust then melting, if not that then cracks etc etc)
That's why I like metal, you know exactly what to expect... Aluminium plate, I think 3mm (or 4 just in case) would be perfect. Easy to cut, light, polishable
The only thing is that - being a guest in UK - I have no clue where to get an appropriate aluminium sheet. Any ideas gentlemen?
Paddy, I just had a striking idea.
What you say to have it laser cut out of aluminium plate by someone (I mean CNC place) following your pattern? I mean once you know it fits? Ordering 10 or so and selling them on with minimal profit to cover your costs and effort involved?
It would need to be for members only, otherwise Renegade guys may be p1ssed and do some stupid things
Now tell me I'm not a genius.
This looks... Well... Frankensteinish...Falcopops wrote:This is the set up I'm using without any sealing to the unserside of the tank and It's been no problem so far. The foam filter sits on top of the lower part of the airbox and the ally frame holds the intake cage in place.
