Gear lever thingy!
rick
Gear lever thingy!
#1 Post by rick » Tue Apr 20, 2010 7:17 pm
Bugger!
Left work a bit early today to have a blast towards Melton Mowbray then North of Loughborough towards Zouch and back down towards Tamworth before meeting a mate at Bassetts Pole...
...but when exactly half way (so 40miles from BP but 40miles into my journey) I was accelerating hard, went into 6th and crack! The gear rod was dangling on the floor having broken at the lever and hanging from the gear selector shaft.
So anyway I pulled over, managed to get her in 3rd and removed the rod and tied the foot pedal to the hanger to stop it flapping. The nut connecting the rod to the foot pedal had sheared... leaving part of the bolt in the threaded hole in the pedal. I've just managed to get it out (used a very small drill bit followed by a larger one to drive it out) which is a relief (I dont have a good history with removing snapped bolts!).
Now, do I need to get the entire assembly, or just a new bolt to fit inside the ball-joint end on the rod? If its just a bolt, does it have to be aprilia specific or would any one do?
Thanks in advance.
#2 Post by Falcopops » Tue Apr 20, 2010 10:50 pm
Are taling about part 8 inthe diagram?
I'd imagine a quick trip to a wreckers would turn up a suitable part, at least the bits are small enough to take with you to test fit.
Did you manage to get the ball out of the socket? How?
rick
#3 Post by rick » Wed Apr 21, 2010 5:15 am
yup number 8 :)
there is a pin on the socket... remove and ball pops out :)
#4 Post by Falcopops » Wed Apr 21, 2010 5:41 am
rick wrote:there is a pin on the socket... remove and ball pops out :)
Too easy, ta. good luck getting yours sorted.
hornetrider
#5 Post by hornetrider » Wed Apr 21, 2010 10:12 am
This has nearly happened to me - twice now the No 8 screw has unthreaded itself from the gear lever - I consider myself lucky it hasn't sheared in the process. It'snow secured in there with superglue!
rick
#6 Post by rick » Wed Apr 21, 2010 10:16 am
Mine didn't come out, just snapped!
Anyway I have found a place that sells the stud, so-called threaded ball stud, and its around 50p or so... will be heading to a bearings/joints place during my lunch hour to hopefully pick some up.
I'll be buying a few and keeping them in the toolbox on the bike methinks!
rick
#7 Post by rick » Wed Apr 21, 2010 11:36 am
Bugger... they didn't sell them :smt011
So I've just ordered a couple of sets... should arrive tomorrow http://www.ondrives.com/bearings-ball-s ... steel.html
rick
#8 Post by rick » Thu May 06, 2010 12:50 pm
Forgot to update - but fitted a complete new set and now works a treat... gear rod a lot less sloppy and gear changes a lot sweeter :)
