Here we go, I am in the proces of fitting a mille swingarm, powder coated black for effect! I was duly cleaning my rear wheel and noticed that my cush bolts were loose! I took wheel off and retighted them adding blue thread lock. Two weeks later, washing again bolts loose only three this time, but, worse still, a bolt nut has sheared off
When I redone the bolts the first time I did notice that the rear spindle nut spacer was spinning with wheel. I duly, retightened to the required spec as per the torque setting. And I regreased the wheel spindle which did shows signs of wear + tear, maybe when the tyre fitter didn't tighten it properly, and this is a professional guy....
There is a 16 front anf 43 back sprocket fitted, back being a stealth sprocket, there was wear on the aluminum where the bolts have turned and scrapped th gold finish and some collapse on the one that sheared off! My concern is that I need a new rear sprocket and have bought 5 new cush bolts. I took the rear cush drive to my local aprilia/ducati specialist and he said that it was knackered in the production process and not with excessive use...
I am worried that there is something wrong with either my sprockets, wheel or cush drive! Before I fit my new mille swingarm I don't want to buy all new sprockets, cush drive, maybe have the same problem
Any help would be appreciated....
