Sticky Front Brakes
Anthrax 336
Sticky Front Brakes
#1 Post by Anthrax 336 » Sun Feb 10, 2008 6:19 pm
Bought replacement brake & clutch levers in nice shiny black instead of the usual chrome ones.
Fitted them last week and went for a ride today. Doh!! front brakes locked up slowing down approaching a junction, I shit my pants!!!! The previous 10 minutes were fine, the brakes were working fine.
Removed the lever to check the fitment and the calipers released instantly. Re-fitted the lever making sure that everything wasnt too tight or binding, checked the lever travel, everything seemed ok.
The same thing happened twice on the way back home.
I checked the lever against the original and found them identical, does anyone have any idea what went wrong?? I will need to swap them back to original and take it for a run (nervously)
#2 Post by Samray » Sun Feb 10, 2008 6:55 pm
Sounds similar to a prob mentioned in this thread? https://www.ridersite.com/viewtopic.ph ... vers#18618
Pierre
#3 Post by Pierre » Mon Feb 11, 2008 12:13 am
Did you sit like a prat waiting for your discs to cool down so the wheel would turn for 30mins like I did ?
Or did you realise pushing the lever away from you free's them. In the end I used the standard oem triangle-thingy-bit-with-adjuster-on with the cheap shit chinese lever on the end as a compromise.
