Resin casting
Resin casting
#1 Post by MartDude » Sat Oct 10, 2009 5:53 pm
Anyone here know anything about this?
I need to fashion some lightweight bar-end extensions (for mounting hand-guards) and was considering casting them in resin.
However I know absolutely nothing about this subject. What sort of resin would be suitable, bearing in mend factors such as weather resistance, resistance to vibration, strength in compression, and things I haven't thought of yet?
Ta
#2 Post by Samray » Sat Oct 10, 2009 6:32 pm
Not completely sure but I believe castings shrink so your moulding might need to be oversize since you are thinking of using the old ones as a pattern.
GregD-UK
Hand guards...
#3 Post by GregD-UK » Sat Oct 10, 2009 9:28 pm
I suggest you try looking on rizoma website, they have a sexy set on there, already made for you fella :smt002
#4 Post by MartDude » Sat Oct 10, 2009 10:04 pm
Thanks Greg, but I need to extend the existing R & G bar-ends by about 20 mm, without adding much weight. Or find some extra-long replacements.
GregD-UK
Bar ends...
#5 Post by GregD-UK » Sun Oct 11, 2009 1:15 am
Demon tweeks do long bar ends on their website. And I think busters do a set as well. Failing that, I would try and source a local aluminum supplier and get ally tubing the same size and cut what length you want get it anodised your colour and fit longer bolts....
Just a thought :smt002
