Reviving Carbon Fibre
back_marker
#1 Post by back_marker » Tue Aug 26, 2008 7:18 pm
When i bought the Falco it came with a carbon fibre hugger fitted. All well and good but it is looking a bit tired as it has some scratches in the top coat and also the surface has gone a bit milky.
Does anyone know of a good, cost effective way to sort this out and make it look new again? Is it just the surface that is affected and if so would I just be able to rub it down with some wet and dry and give it a couple of coats of laquer?
- Steve McQueen
#2 Post by Gio » Wed Aug 27, 2008 2:49 pm
Think you need a new one :smt012 :smt005
#3 Post by Falcopops » Thu Aug 28, 2008 2:44 am
IIRC there was a discussion about this very thing on AF1 a while back. Would be worth having a search over there.
#4 Post by Nooj » Fri Feb 20, 2009 6:14 pm
How about heat damaged carbon fibre that's gone a bit brown, any fixes?
