Throttle body sync tool
Posted: Tue Jun 24, 2008 12:16 pm
Anyone know where I can get one? rsvr.net used to sell a budget one, that you sit over the throttle body intakes, was about £20 or so - can't find them anywhere on the net. Needs to be fairly idiot proof (after all, I'll be using it
I've seen the fancy ones (like Carbtune an so on), but didn't really want to spend that much on one, also don't want the hassle of having mercury in the garage so don't really want carb sticks.
Suggestions/links?
Ta muchly
Posted: Tue Jun 24, 2008 1:34 pm
Can't provide links at the mo (having a few PC issues), but the carbtune jobbies don't use mercury they're just big metal rods in glass tubes.
To sync cylinders properly I'd always use something that allows you to see what's happening to the other cylinders as well as the one you're working on. Adjustments to one will affect the other.
Phew! due to the time difference I think Im just gonna get this in before Tweaker.
Posted: Tue Jun 24, 2008 1:50 pm
by Tweaker
Haven't seen the Evo tool for a while either and someone on the US forum was asking where to get one too.
I've got the Carbtune sticks and, although more expensive, they're good. Also, for info, they're mercury free as they use stainless steel rods.
Edit: In spite of the time difference, Dale beat me to it
Posted: Tue Jun 24, 2008 1:55 pm
Damn close, but the but the black ones just can't hack it.
INCOMING
Posted: Tue Jun 24, 2008 2:01 pm
by Tweaker
I'm not biting.......
I'm trying not to bite.....
I'm really NOT going to bite......
Oh bugger..... YOUR JUST JEALOUS
Posted: Tue Jun 24, 2008 2:16 pm
Thanks for the tips guys, may look at one of the Carbtune systems given what you've said, the bike's running a bit rough atm, didn't want to spend too much to see if this is the reason, but the bike has always felt a lot smoother after each service, when they've done this - if it's happening mid-way between the services, guess I'll just have to invest in something
One follow up query - is there a specific vacuum level to use, or is it just a matter of syncing the two pots to each other - IIRC the method on Ken's site is about feel and educated guess-work - I've not got the experience doing this sort of thing, so would prefer some specific numbers if they're available
Cheers guys
Posted: Tue Jun 24, 2008 7:48 pm
by BikerGran
Balancing carbs is a favourite job for me, though I have the set with circular gauges uinstead of the tubes and the ones wityh tubes are definitely 100% better IMO.
Problem with the round gauges, there's always some flutter and though you can adjust them, if you adjust all the flutter out there's no reading.
No specific figures, all you're looking for is balance.
Posted: Tue Jun 24, 2008 8:20 pm
if you cover postage, you can borrow my evo v twin throttle balancing thingamajig
has never been used so is still in original plastic
I tend to acquire such things when I see them :)
Posted: Wed Jun 25, 2008 7:10 am
Thanks for the offer, but I think I'm going to procure something myself.
Hate spending money (or rather, getting caught!), but love shiny new toys
Posted: Thu Jun 26, 2008 4:13 pm
by paddyz1
I have a first generation carbtune set (the mercury type) I got them almost 18 years ago (i know that 'cos it was the same year my daughter was born). Never had any issues with them except having to get a new syringe for setting them up. They are still going strong and work perfect. They have plugs in them which allow air through but not fluids. I know this because I tested them. I always store them upright but I know they will not leak unless someone does something stupid to them.
Posted: Thu Jun 26, 2008 7:50 pm
by BikerGran
I learned on a borrowed set of mercury ones, definitely the best!
Posted: Mon Jul 28, 2008 8:20 pm
by Viffer
I did something stupid with my carbtune..................dropped 'em on their end and the mercury hammered its way out all over the garage floor
