Falco valve clearance checking
Posted: Mon Jun 11, 2007 10:49 am
by danowat
Bikes just ticked over to 9000 odd miles, so the valve clearance check is coming up, now I do all other servicing myself, but this seems a little........involved.
Has anyone here done it themselves?, is it a pig of a job and best left to a stealer?, if so, how much do they sting you for it?
Posted: Mon Jun 11, 2007 11:11 am
by fastasfcuk
i'd check them my self but if they needed adjusting which i've been told is rare i'd pay.i was quoted £140 do'nt know if that value or not. :smt017
Posted: Tue Jun 19, 2007 10:26 pm
by HisNibbs
I' checked mine myself and like most others it seems, they didn't need adjusting and were exactly the same as they were 9000 miles earlier. It is a fiddley not diffucult job to check them, so allow plenty of time and use a good set of small sockets. If you try cheap & nasty ones they can have so much play you wont have space to click the ratchet.
Also when re assembling, I'd advise some gasket goo around the sensor wire otherwise you might like me, have to refit the covers again to fix a small oil leak.
Posted: Sat Feb 14, 2009 6:43 pm
by macy
Just examined mine last month........all within tolerance no adjustment needed yipeeeeeeeeeeeeee.
Posted: Sat Feb 14, 2009 10:03 pm
by Falco9
Worth remembering that the engine needs to be absolutely clap cold. If you do it yourself, do them the day after you ride home.
However if your dealer rings you to say it's ready the same day you dropped it off, they haven't done them. A dealer will need 2 days to do the job properly
F9 :smt006
