Hola!
Does anyone know the bore of the brembo clutch pump on early Tuonos, RSVs and all Falcos?
It's going to be either 12 or 13mm and I want to get the right KTM/Honda seal kit in before I dismantle it (even though I'll likely only be able to use the main seal)
Unless of course you know the actual kit needed as Aprilia don't do them!
Clutch pump seal diameter?
- KitchenSync
