Apart from dribble coolant. Comes out the expansion tank then goes back in.
If it's supposed to be a level indicator then I need some coolant, and a bit of pipe, and some clips. Temps are the same as they've always been.
What's this little pipe do?
- randomsquid
- Wear the Fox Hat
Re: What's this little pipe do?
It israndomsquid wrote:
If it's supposed to be a level indicator .......
You dorandomsquid wrote:
...... then I need some coolant, and a bit of pipe, and some clips.
- randomsquid
- Wear the Fox Hat
