#1
by DavShill » Sun Dec 14, 2014 2:44 pm
Hi chaps - just been out doing some errands on the Tiger and noticed the throttle sticking once the heated grips have warmed up. It's an 09 bike with factory fit grips. Is it time to renew them? Will a squirt of WD40 help or damage? Anyone experienced this on their bikes?
DavShill on Sun Dec 14, 2014 3:20 pm, edited 1 time in total.
#2
by Falcopops » Sun Dec 14, 2014 3:00 pm
I prefer to use a dry lubricant like graphite. If that's not available I use a silicone grease as it doesn't cause rubber items to swell.
#3
by DavShill » Sun Dec 14, 2014 3:19 pm
Thanks Dale, I've got some silicone spray lube, I'll try that.
How's things down under - ready for a hot and sunny Christmas?
#4
by Falcopops » Sun Dec 14, 2014 3:36 pm
Hot is an understatement. It's just started raining so cooled the air a bit. I'll be back in the uk in just over a week and apparently there's already snow on the ground in Scotland. I'm really not looking forward to the cold.
I'd be checking that your grips aren't doing something odd when they heat up.
#5
by fatboy » Sun Dec 14, 2014 4:45 pm
WD 40 actually state that the product can damage rubber and some plastics
#6
by DavShill » Sun Dec 14, 2014 5:12 pm
I'll get some graphite stuff I think.
- Wear the Fox Hat
#7
by randomsquid » Sun Dec 14, 2014 8:00 pm
I'd use red rubber grease, but then I've got some in the toolbox already.
#8
by Falcopops » Sun Dec 14, 2014 10:38 pm
If you've got silicone spray use that, it's not going to harm any rubber, that's what divers use on their sealing rings and I use it on brake seals and pool seals and it doesn't cause the rubber to swell.
The throttle tube should be a plastic/nylon material so not too susceptible to swelling.
#9
by DavShill » Mon Dec 15, 2014 7:27 am
ok thanks Dale.
#10
by MartDude » Mon Dec 15, 2014 6:01 pm
Some forms of Nylon do absorb water, and swell.
nicketynoo
#11
by nicketynoo » Mon Dec 15, 2014 8:47 pm
I tend to use KY jelly as it doesn't cause nylon or rubber to swell but definitely has a swelling effect on other more natural materials.
I don't care if you lick windows,
Take the special bus
Or occasionally pee on yourself.
You hang in there sunshine, you're special!
#12
by Falcopops » Tue Dec 16, 2014 2:07 am
nicketynoo wrote:I tend to use KY jelly as it doesn't cause nylon or rubber to swell but definitely has a swelling effect on other more natural materials.
The amount of swelling is directly proportional to how well you rub it in, apparently!
TwinkietheKid
#13
by TwinkietheKid » Tue Dec 16, 2014 3:07 pm
Falcopops wrote:nicketynoo wrote:I tend to use KY jelly as it doesn't cause nylon or rubber to swell but definitely has a swelling effect on other more natural materials.
Well, this thread raised some welts.
'03 Falco, in the fast colors
'15 Caponord, look upon my toy, ye Mighty, and despair!
Frenzies bewilder, reveries perturb the mind.
nicketynoo
#14
by nicketynoo » Tue Dec 16, 2014 3:11 pm
Don't really understand what the problem is! I quite enjoy a good Hot throttle!
#15
by DavShill » Tue Dec 16, 2014 10:00 pm
I knew this would degenerate into such smut. You should be ashamed of yourselves for even thinking about it.
How do i get the jelly between the thin skin, where you grip it, and thick bit inside?
