Grease for my ring?
Posted: Wed Nov 21, 2012 1:28 pm
by MartDude
Injector o-rings, that is. On the BMW K100.
Would silicone grease be ok? If not, what else?
Posted: Wed Nov 21, 2012 2:56 pm
by MartDude
I did a fairly extensive Google search on this before posting - looked at quite a number of threads on (mainly) car,bike & boat forums. There seems to be 2 principal schools of thought on this: use silicone grease, petroleum-based products can cause o-rings to swell; and, use clean engine oil/grease, silicone can damage o-rings. Not being an expert on lubricants and their effects on different materials, I'm still in the dark.
Posted: Wed Nov 21, 2012 3:24 pm
by slickliner6
maybe a little off topic but,,,,,,,,,
when we used to use the old copper slip at work it was found to cause o-rings to harden and become brittle.
Posted: Wed Nov 21, 2012 4:15 pm
by randomsquid
Dunno but kawasaki specify silicon grease for the sliding (occasionally) bits of my callipers. That's steel pins sliding in rubber gaiters. You can get big tubes from industrial supply places like RS components for about the same price as tiny amounts from car accessory places.
Posted: Wed Nov 21, 2012 5:27 pm
http://www.wynns.co.za/greases.htm
We use this when building pneumatic valves up mart on the o rings it is a lithium type grease. It should be more than adequate
Posted: Wed Nov 21, 2012 7:01 pm
by Willopotomas
I use red rubber seal grease. The same stuff ye use when doing fork seals etc.
http://www.opieoils.co.uk/p-999-fuchs-r ... omers.aspx
Posted: Wed Nov 21, 2012 7:38 pm
by MartDude
Is that sufficiently heat resistant for injector o-rings, Will?
Posted: Wed Nov 21, 2012 7:56 pm
Another vote for red rubber grease here. It's de rigeur when reassembling brake calipers. Brakes can get pretty damn hot, as well...
Posted: Wed Nov 21, 2012 8:44 pm
Martdude, you only need the lube for ease of assembley,
red rubber grease wont hurt any seal at all (modern grease is white )
Wait for interjection re Canadian weilding big club.
Next time you need to think about the injector seals, it will be time to replace em
Posted: Wed Nov 21, 2012 10:23 pm
by Willopotomas
MartDude wrote:Is that sufficiently heat resistant for injector o-rings, Will?
Well my K100 is still going after feck knows how many thousands of miles since clearing them out. Had the bike 10 years, must've covered a good 40-50,000 miles since. Ah, back in the times when I only rode my bike all day.. *sigh*
