rear caliper
- scottyni
- Clubman Racer
rear caliper
sticky piston which sorted.... then....
pushed the piston in and i put a hole in the face of the piston. little bar i use slipped.
better too get a caliper or replace piston??
any1 have a rear caliper ????
if you can't ride it....
OR take it too bed...
IT AIN'T WORTH HAVIN...
Sorry, the only one I've got is on my bike.
I know spares for Brembos are hard to find but Mangocrazy did (eventually) uncover a source of the almost-unobtainable seals:
https://www.ridersite.com/viewtopic.ph ... embo+seals (that thread does deliver in the end!)
I'm guessing they may do pistons too.
That said, Ebay usually throws up some callipers.
Also SteveP has been breaking his Falco - maybe he's still got the calliper to sell - worth enquiring (I've had a few bits off of him - he's a pleasure to deal with).
Also, some time ago I remember there was an upgrade calliper that people fitted. Think it was slightly bigger and worked better - search here or the old forum and I think it will tell you.
- scottyni
- Clubman Racer
i thought the piston was a solid block, noone more surprised than myself.
got a caliper sorted out, pick up tomorrow.
got all the bearings of wemoto just last week quick service if needed by others
cheers for the info guys
- Track Day Addict
