I recently bought a cheap satnav that came with the standard suction type of car mount - and of course that is bugger all use on a bike :(
Now even though the unit is not waterproof, I reckon that if it was kept under the fairing or nose cone, then it would be ok - but how to get it there with out cutting my beloved falco about?
Now as many of you know, I am a very careful red sea pedestrian, and I hate the idea of spending money on anything bar beer and pipe tobacco.... so having thought about ity, and having looked at other peoples solutions, I decided to have a go.
First thing was the car mount - i took the "sucker" end off and noticed the large circle that was left - and the rectangular space where the active part of the sucker bar was. Five minuts later, and dremel safely packed away again, I was left with the mounting just having a U shaped end. This tied in with what I had already seen below the Falco dash - there is a hole in one of the mounting plates there that looked like it would be perfect to attach something to.
I stripped off the front of the bike, and exposed the bar - and offered up the mount to it - would you believe that the U shape was an almost exact fit ??
Next up, out came the dremel with a tiny drill bit, and a pilot hole was drilled, straight through both sides of the U.
Offered up again, still a nice fit - so hole taken out to 4.5 using a slow wood bit - 4 would have been too tight for the bolt i had ready. As it was the bolt did cut a little thread for itself :)
Here it is so far, view from above and the front of the bike, looking back:
and this is a side view that shows how the bar fits on to the U shape - also note I have used a double nut to try and ensure it stays put :)
Now before I rerally locked everything down, I offered up the dash to ensure that it works and all is ok:
Note that the bracket is off centre - but due to how I placed it the satnav will be in the centre of the cockpit
and here we go - the final shot with screen etc fitted
and yep, am well pleased, took about two hours start to finish :)
