Just the plugged in here at XYZ time, and then plugged in here at ABC time, distance and time = speeding. If I remember correctly there were case of the same on tolls booths, with ANPR, in Europe some where. You just get sent the ticket.mangocrazy wrote: ↑Tue Dec 31, 2019 9:57 pmI must admit I hadn't thought of that. Would be very easy to download the contents of memory and logs and scan for any non-standard components while charging...
If it was a car, I wouldn't be bothered/worry, as you can't maintain speed over distance with a car. But having gone from Oxford services to Lingfield in just under an hour, on a bike. You've already had a black box fitted, whether you wanted it or not.
