HELP PLASTIC SURGERY REQUIRED
gempip
#16 Post by gempip » Sun Jun 10, 2007 9:31 pm
jam wrote:Look in your local car spares place, and find a product by an american company called VersaChem, it's a two part plastic welding system. Vee out the crack drill small hole at eother end to stop it spreading and then squeeze out the equal amounts and mix apply to crack and repeat on inside, sand down smooth over will a little filler and paint. Around a fiver a tube, dead easy and a hell of a lot cheaper than the very similar Wurth system. I use it all the time, sets in around 15 mins depending on temp, and is fully cured in 1 hour. Wurth system comes with loads of refills and mixing tubes and appicator gun for around 200 quid. Bonds different types of hard plastics, unlike thermo welding rods, and can be moulded to make lugs etc.
:smt002 Cheers m8 I will keep that for further reference Unfortunately mine was a little more than a crack, more like bloody great holes :smt012
jam
#17 Post by jam » Sun Jun 10, 2007 11:03 pm
It's fine for doing larger repairs, I've used it to remake mssing sections of panels, and lugs and tabs too
