NEED a ride!
Posted: Tue Sep 07, 2010 9:46 pm
by rick
Been on holiday for a couple of weeks, went out on the Falco Sunday only to be met by Monsoon weather in Leominster!
Weather should be good tomorrow so will be heading out after work... either Bridgnorth/Worcester/Leicestershire... anyone out for a run after 6pm?
Posted: Wed Sep 08, 2010 5:46 pm
by old git
Only just seen this so, bugger!
Am thinking of having a blast out from Worcester on Sat. if you are about, & pending some dry weather, I don't fancy leaning in the wet.
Looking at Worc, down the A38 thro Tewkesbury, towards Gloucester then left under M-way across towards Morton-in-March, Fishh Hill bends, then out across country towards stratford & back, should be like 100 miles.
Drop me a line if anyone is interested & pray there is still some dry sky about.
Posted: Wed Sep 08, 2010 9:03 pm
by rick
Not a bad run tonight, Kiddy then up to Bridgnorth, over to Ludlow but turning back up Clee Hill... then Tenbury, Leominster and A44 to Worcester before winding back up to Brum.
I would be up for that on saturday for sure, but wifey is at a hen do so I have little 'un all weekend... hopefully we can do it before the winter sets in!
My clutch fluid usage is now unreal... from max to min in 110 miles tonight! Finally removed the sprocket cover and the leak is at the bottom of the slave cylinder near the bottom bolt... it bloody bubbles out when the clutch lever is pulled in! There looks like a little recess there!
Anyway, thats OT!
Posted: Thu Sep 09, 2010 8:09 am
by furygan man
will try and link up with you at some point Rick but will usually be a Fri eve or Sat morn, the next pos w/e will be 17/18 then not again till early mid Oct after my hols...will monitor the weather breaks!
