Sticky mouse
Posted: Sun Dec 11, 2011 6:11 pm
by MartDude
Or rather, cursor
It's started 'pausing', if that's the right word - move it to another part of the screen , and, en route, and seems to stop to have a think for, sometimes, half a second, or sometimes perhaps two seconds.
When playing Age of Empires (I know, old hat but I like it) part way through a game it'll freeze up altogether, although the game's still running, and the only way to get out is to switch off the pooter at the mains.
The only change I've made recently was to uninstall AVG and install Avast.
The mouse is a Microsoft optical mouse, a replacement about a year ago for the original mouse.
Pooter is a Dell PC, running Vista; about 3 years old, I think.
Help, please
Posted: Sun Dec 11, 2011 6:27 pm
Try a diff mouse? if only as the first step of elimination.
Posted: Sun Dec 11, 2011 6:56 pm
by Dalemac
is it wired or wireless? connect it to a different computer/laptop and see if the cursor pauses then.
First thing i would do ia go to device manager and see how many mice your system is recognising. Sometimes dublicate devices can cause similar problems.
Posted: Sun Dec 11, 2011 7:39 pm
by BikerGran
Just as with bikes, check the simple things first - check that it's plugged in tight! (Had the same problem recently and it turned out the cats had been playing behind the computer!)
Posted: Sun Dec 11, 2011 8:02 pm
by randomsquid
Is the hole in the bottom crudded up?
Have you changed the surface you're mousing on? They sometimes get confuddled by shiny.
Are you getting hard drive thrashing, fans spinning up or similar evidence of the PC working hard when the pointer stops playing?
Posted: Sun Dec 11, 2011 8:44 pm
randomsquid wrote:Is the hole in the bottom crudded up?
+1 for the computer, sounds like the AV software might be causing a bit of a stutter
Posted: Sun Dec 11, 2011 8:51 pm
by MartDude
Somewhat.
However, having just found a spare, new mouse - can't remember why I had it - and plugged it in, everything's working fine again. Out of curiosity, I'll try & cleean the old one & see if works ok.
Thanks, everybody.
by randomsquid
Firestarter wrote:randomsquid wrote:Is the hole in the bottom crudded up?
That'd be my guess. Far too intrusive some of it.
Posted: Sun Dec 11, 2011 8:53 pm
by MartDude
Went over to Avast largely 'cos of recommendations on here.
Not being that au fait with IT stuff, I rely on heavily on the advice of such as your good selves.
Posted: Sun Dec 11, 2011 9:00 pm
by randomsquid
Glad you've sorted it, plug in bits can be a pain sometimes for no good reason. I had a keyboard that kept falling out with the PC until I plugged it in a different hole.
Posted: Tue Jan 03, 2012 7:51 pm
by BikerGran
I love these technical terms
Posted: Wed Jan 04, 2012 6:24 pm
by randomsquid
BikerGran wrote:I love these technical terms
That's what the judge said too.
