Smart TVs?
Smart TVs?
Are they worth having, or are they just a gimmick?
I need to replace our TV with one more suited to my failing hearing, and smart tellies don't seem hugely more expensive than the 'ordinary' kind.
2 of my sons have smart TVs - I'll ask them whether they actually use any of the other features or just use their PCs for such things.
You'll probably find that Smart TVs come with a better range of input connections as a bit of a bonus (assuming you might use them)
- Falconihlist
Current telly is a Panasonic Viera, but it's 7 - 8 years old, and it seems that current soundbars/speaker systems can't be connected without losing the remote volume control. Looked into connecting it to the hi-fi, but the same applies.
One thing to note, most of the TV providers like BT and the like have BBC iPlayer and all that jazz. This is more or less what the "Smart TV" does.
IMO unless you're going to use the features more that BT/Sky/Virgin go for it otherwise just get a decent LED or the like.
PS Your DL and UL speed is fine and will run the features, having said that i EVERYONE in the house is online streaming videos or playing games it may hinder it a little!
PPS....Falconihlist: BT are giving you an upload speed that decent!!!!!?!?!?!?!
- Falconihlist
ok
what the smart tv would give you - as iirc you have generic tv, not sky or similar, is access to catch up - BBC i player, etc as well as access to love film and netflix
personally, for our family, we have both - mainly because the kids can access those by their consoles and watch what they wish
if i was forced to choose - netflix - every time - i like some of their home grown shows
other things are also available on smart tvs - facebook etc - but all much of a muchness if you have a pc
most manufacturers also have their own channels - sony have some form of sony tv channel for instance
if i was buying a new tv - i would buy a smart tv
i would probably also buy a 3d tv - NOT to necessarily watch 3d tv, but because the screen quality is often higher....
- randomsquid
- Wear the Fox Hat
Add a sub to http://www.unblock-us.com/ and you can watch the Netflix content for any country of your choosing. $5 a month.Aladinsaneuk wrote: if i was forced to choose - netflix - every time - i like some of their home grown shows
See what's on where on http://www.moreflicks.com/
- Falco Frank
Same problem as OP with our Panasonic TV but went the soundbar route - ASDA had a great Sony with subwoofer but I missed out on the last one, £90 instead of £140 I think, as I couldnt remember if our TV had optical digital output.
Which it soddin does as it happens.
Trying a cheapy Polaroid £50, at the moment and considering its not big and has bluetooth - its not bad at all BUT in front of the TV its TOO TALL and blocks the IR sensor for the TV control...
However, Tesco's are selling (but sold out - Grrrrrr) of a crackin £70 Sharp, slimline soundbar that turns on automatically when it receives a signal input!
Might have to try that next.
- Falco Frank
No, you're not. I own two CRT tellies and they're both fine. No need to change as far as I'm concerned. And the monitor on my PC is also a CRT - a Dell 20 inch flatscreen jobbie with Trinitron tube and exceptional image quality.D-Rider wrote:..... so am I the only person here with a classique crt type telly as their main tv?
