No it's not a black one!!...(Updated!)
#31 Post by D-Rider » Sat Feb 05, 2011 10:28 am
...... and will there be a fairy on the top :smt003
Just watched the vid - using the headlight reflector with those indicators is excellent - unless you have main beam on and they are washed out - but if there is anyone to signal to in front, you won't have main beam on.
:smt023
#32 Post by furygan man » Sat Feb 05, 2011 10:56 am
D-Rider wrote:...... and will there be a fairy on the top :smt003
:smt003 A big fat fairy, had my shock serviced and had to go up to the next spring :smt011 ...rivita anyone?
#33 Post by D-Rider » Sat Feb 05, 2011 12:36 pm
I spotted your confession over on "the other place" and felt it should really be shared with Ridersite too .....
furygan man on the AF1 forum wrote:[Don't tell anyone but i melted the first one in the oven, got mixed up with 'C and 'F...
:smt044 :smt044 :smt005 :smt005 :smt081 :smt081 :smt082 :smt082
#34 Post by Samray » Sat Feb 05, 2011 1:00 pm
#35 Post by furygan man » Sat Feb 05, 2011 1:13 pm
D-Rider wrote:I spotted your confession over on "the other place" and felt it should really be shared with Ridersite too
:smt013 :smt013 (...i suppose i deserve it!)
#36 Post by furygan man » Mon Feb 28, 2011 4:45 pm
Black Millie swing arm fitted :smt001
#37 Post by Aladinsaneuk » Mon Feb 28, 2011 6:14 pm
and the pictures are where exactly? :)
#38 Post by furygan man » Mon Feb 28, 2011 6:36 pm
Only saw it in Griff's workshop and was dark when i got it home in the van (you know how he likes to talk?), the lighting has to be just so...and still waiting on the correct rear sprocket and switchgear to be fitted, you know how fussy people are about detail? won't be down in 'Inckley now for another couple of weeks!! :smt012
...surely there's someone out there with pics of Wintered fettling?
#39 Post by furygan man » Mon Apr 04, 2011 1:42 pm
Phase two mods! :smt003
#40 Post by D-Rider » Mon Apr 04, 2011 5:34 pm
Looks good .... now screaming out for a Mille exhaust so that you can see that lovely swingarm
#41 Post by furygan man » Mon Apr 04, 2011 5:36 pm
D-Rider wrote:Looks good .... now screaming out for a Mille exhaust so that you can see that lovely swingarm
Andy...don't give me anymore ideas please!!!! :smt011
*Edit- so how does that differ...we're not talking one pipe are we as i don't like that, have considered getting some high level link pipes made as an alternative?
#42 Post by furygan man » Wed Apr 06, 2011 8:23 am
Is this the sort of thing you mean? I like this...would it work?? Is this similar to Pete's?
Midnight Rider
#43 Post by Dalemac » Wed Apr 06, 2011 12:42 pm
those mirrors look swish, what are they from?
#44 Post by furygan man » Wed Apr 06, 2011 12:59 pm
Dalemac wrote:those mirrors look swish, what are they from?
RSV 04 on, but you'll need adapter plates too!
#45 Post by Aladinsaneuk » Wed Apr 06, 2011 1:06 pm
mirrors are off an >2004 rsv using bill's adapter plates off af1.....
and yes - the exhausts do work - i have used renegade high mounts from a mille on mine
the job to fit them is straight forward - you need a full mille set of headers and collector box, as well as the actual cans
(Oh - make sure you get one of the later mid sections - just incase you go for the modded mid pipe in the future.)
you will also need an rsv oil tank - you can make that fit onto the standard falco oil cooler with a replacement length of oil pipe, or you can fit a mille cooler.
you will need to dremel out 3/8 inch off your skidmarx belly pan on the left side - very easy job - and it is obvious where it needs a trim!
alternatively, you could look around for a set of falco high mount canns - they do exist
finally, if you look over in the coventry area, there may be a chap over that way with a spare set of interesting exhausts - look for 55 year old male, answers to the name of badger....
