Amateur Photography (no boobies though)
#16 Post by D-Rider » Sat Apr 04, 2009 12:09 am
We do have a Sticky in the technical section that tells you just about all you need to know about registration plates.
Here's a link to it: https://www.ridersite.com/viewtopic.php?t=4409
The relevant rules on visibility seem to be:
(2) A registration plate must be fixed on the rear of
(a) the vehicle, or
(b) where the vehicle is towing a trailer, the trailer, or
(c) where the vehicle is towing more than one trailer, the rearmost trailer.
(4) Except as provided in paragraph (3) the plate must be fixed in the manner required by
paragraph (5).
(5) This paragraph requires the plate to be fixed—
(a) vertically or, where that is not reasonably practicable, in a position as close to the vertical as is reasonably practicable, and
(b) in such a position that in normal daylight the characters of the registration mark are easily distinguishable from every part of a relevant area having the diagonal length specified in paragraph (6).
(6) The diagonal length of the relevant area is—
(a) in the case of a mark having characters the width of which is at least 57 millimetres, 22 metres,
(b) in the case of a mark having characters the width of which is 50 millimetres, 21.5 metres,
(c) in the case of a mark having characters the width of which is 44 millimetres, 18 metres.
the character width for our bikes is 44mm.
So ... It should be fixed on the back of the vehicle ..... should be vertically mounted ..... should be visible from every part of an area behind the bike that has a diagonal of 18 metres - so I guess the most favourable interpretation is of a square with 18m diagonals with one of the 4 corners placed on the back of the bike.
..... arguing for absolute compliance of nooj's plate may be a bit of a challenge ......
AlBeeFalco
#17 Post by AlBeeFalco » Sun Apr 05, 2009 9:08 am
Very nice bike Nooj,
And there was I thinking my bog standard '05 Falco looked good!! I'll have to start a mod piggy bank!
#18 Post by Nooj » Tue Aug 31, 2010 10:42 pm
Where'd all the pictures go??
#19 Post by Kwackerz » Tue Aug 31, 2010 10:45 pm
Photofuckit have either changed the location of the pics, have cancelled your photofuckit account, or you have?!
#20 Post by Samray » Tue Aug 31, 2010 10:47 pm
Dont their accts lapse if you don't use em for 6 months or so?
I seem to recall getting reminders from them to log in to activate.
EDIT:
If you have not logged into your Free account in the past two years and you haven't had any active links in the last week, your account will be deleted. See Deleted accounts for details.
:smt017
#21 Post by furygan man » Fri Oct 29, 2010 1:04 pm
where the pics gone Nooj? I'd just noticed you'd chopped your screen and upper fairing...couldn't work out why it looked so aggresive, when you've hacked it down did it just need sanding, i'm thinking of just doing the bit of the sceen that sticks obove the end of the fairing...would like to one day get another Falco and tweak it like a Tuono but the other half say's NO!
#22 Post by Nooj » Tue May 10, 2011 9:13 pm
Where did my pictures go??
#23 Post by Samray » Tue May 10, 2011 9:18 pm
You can repeat the question but I'm not gonna repeat the answer. :smt002
#24 Post by Nooj » Tue May 10, 2011 9:32 pm
Whoa! Deja vu!
