GPZ900R GPZ900R('90 European models) GPZ900R for DOMESTIC MARKET
Type 4-stroke, 4-cylinder, dual over head camshaft, liquid-cooled
Displacement [cm3] 908
Bore and stroke [mm(in)] 72.5x55.0
Compression ratio 11.0
Maximum horsepower [PS/rpm] 115 / 9,500 * 108 / 9,500 * 89 / 9,000
Maximum torque [kg·m (ft·lb) / rpm] 8.7 / 8,500 8.5 / 8,500 7.3 / 6,500
Ignition system transistor
Lubrication system Wet Sump
Starting system Electric
Carbrstor type Keihin CVK34
Transmission type 6-speed,constant mesh,return shift
Clutch type Wet multi disc
Final drive system Chain
Gear ratio 1st 2.800(42 / 15)
2nd 2.000(38 / 19)
3rd 1.590(35 / 22)
4th 1.333(32 / 24)
5th 1.153(30 / 26)
6th 1.035(29 / 28)
Primary reduction ratio 1.732(97 / 56)
Final reduction ratio 2.941(50 / 17)
[2.882(49 / 17)] 2.823(48 / 17) 2.764(47 / 17)
Overall drive ratio 5.276[5.170] 5.065 4.959
Frame type Tubular, Diamond Diamond
Castor(rake angle) [degree] 29
Trail [mm(in)] 114 118 114
Tire type Tubeless
Tire size Front 120/80V16-V250 120/70V17-V250, 120/70ZR17 120/70-17 58H
Rear 130/80V18-V250 150/70V18-V250, 150/70ZR18 150/70-18 70H
Brake type Front Dual Disc
Rear Single Disc
Braking distance [m/kmh(ft/mph)] 12.5 / 50 13.5 / 50
Suspention type Front Telescopic, air Telescopic
Rear Uni-trak, air shock Uni-trak
Overall length [mm(in)] 2,200
Overall width [mm(in)] 750 730 740
Overall height [mm(in)] 1,215 1,220
Wheelbase [mm(in)] 1,495 1,500
Road clearance [mm(in)] 140
Dry weight [kg(lb)] 228 234
Minimum turning radius [m(in)] 2.7 2.9
Fuel tank capacity [L] 22
Engine oil tank capacity [L] 3.0
Key:
[ ] is '85-'89(A2-A6)models.
* is '85-'86(A1-A3)models.
'87-'89(A4-A6)models is 110ps.
Source of Information : Kawasaki Japan
GPz 900R Specification list
