Aladinsane's Falco
Aladinsane's Falco
From the front:
R&G crash bungs on forks
Ohlins cartridges inside showa forks - showlins!
4 Pad calipers from RSVR factory
Braided HEL brake hoses
smoked headlight cover
HID low beam conversion
Dip beam always on switch mod
Bars over triple conversion
RS125 long stalk mirrors
Pazzo copy levers
Oxford heated grips
Mounting plate under dash cowl for garmin zumo 660
smoked blister front indicators
Skidmarx Double Bubble Screen
Renegade Airbox
Renegade Mille Mid section exhaust
Mille exhaust headers
Mille oil tank
Renegade Mille high mount exhausts
Power commander 3
Renegade +1(0) chip
Iridium spark plugs
54mm throttle bodies
Sergeant Saddle
Scottoiler fitted to front sprocket
MPL clutch slave (currently being replaced)
Ohlins remote pre load rear shock
Mille swing arm
Oz wheels front and rear
Aprilia performance rear sets
Skidmarx Belly Pan
Integrated rear light assembly by Nooj
Smoked rear lens
Self fabricated tail tidy
thinks that is about it....
Pazzo copy levers
Oxford heated grips
Renegade Airbox
Mille oil tank
Power commander 3
Renegade +1(0) chip
Iridium spark plugs
Sergeant Saddle
Mille swing arm
Skidmarx Belly Pan
Smoked rear lens
- flatlander
You forgot the wheels cab and other bits normally associated with a green flag rescue truck
