Clutch lever pin
General Aprilia banter
old git
Clutch lever pin
#1 Post by old git » Sat Nov 03, 2012 4:09 pm
The adjusting pin that fits inside the pivot on the end of the lever, anyone know the part number or where one can obtain a spare, have replaced the lever with some shines new ones, but had to use the pin of the old, would rather replace this as well.
#2 Post by MartDude » Sat Nov 03, 2012 4:21 pm
It's not listed or available as a separate item, unfortunately. I had to re-use the old one when I changed my levers. I'm sure someone with a lathe could fabricate one.
BTW, for future reference, the Futura clutch pump assembly - reservoir, master cylinder, lever - is the same as the Caponord's - being in production for much longer, Capo parts are more readily available - some Capo parts are interchangeable
