rear caliper on fire
Nogwuy
#1 Post by Nogwuy » Wed May 16, 2012 5:19 pm
think its time to overhaul my rear caliper and replace disc & pads. touched the rear brake coming down a slip road off a47, felt like it was binding & brake padal a total sponge so pulled over. smoke and flames (rubber bleed nipple and plastic brake light switch cable both touching caliper alight!) good job i had a bottle of water in my bag.
got home ok after cooling off (front brake only), just stripped rear caliper and pads are almost just metal left, my bad for not checking i know, but no advisory on mot less than 1000 miles ago.
any advise on work needed to the caliper, or on what disc & pads to replace them with much appreciated.
fat people are harder to kidnap
Re: rear caliper on fire
#2 Post by blinkey501 » Wed May 16, 2012 6:44 pm
Nogwuy wrote:think its time to overhaul my rear caliper and replace disc & pads. touched the rear brake coming down a slip road off a47, felt like it was binding & brake padal a total sponge so pulled over. smoke and flames (rubber bleed nipple and plastic brake light switch cable both touching caliper alight!) good job i had a bottle of water in my bag.
Clean the paint off the pad edges so they slide into place easily.
If you have to tap them into place they are too tight and will stick on when brake has been used.
Copper slip the edges and the back of the pads on the steel has this will stop sqealing of the brakes
Nogwuy
#3 Post by Nogwuy » Wed May 16, 2012 6:55 pm
[/quote]
Copper slip the edges and the back of the pads on the steel has this will stop sqealing of the brakes[/quote]
thanks for the tip
i have now split down the caliper completely and need to replace the seals, was going to go for these
http://www.ebay.co.uk/itm/140702700054? ... 5533wt_952
and thinking about replacing the disc with this
http://www.ebay.co.uk/itm/APRILIA-RS125 ... 712wt_1185
these pads
http://www.ebay.co.uk/itm/370340395914? ... 1275wt_952
or these?
http://www.ebay.co.uk/itm/320755152589? ... 686wt_1185?
& some nipple covers!
http://www.ebay.co.uk/itm/300626933229? ... _938wt_952
#4 Post by fatboy » Wed May 16, 2012 7:33 pm
Obvious but check the pistons and bores for corrosion and pitting,even the smallest manky bit can stop the piston receeding
Be very careful if you are handling any burnt seals,they can produce a very nasty acid thats not kind to flesh
#5 Post by blinkey501 » Wed May 16, 2012 8:17 pm
I saw this disk when listed and did keep it in my watch list.
I take it you bought it? I know it was'nt around for long :smt087
Nogwuy
#6 Post by Nogwuy » Wed May 16, 2012 9:11 pm
Yep I bought one. All the others for simular price were used standard ones so seemed daft not too. He has sold a few so I bet he will have/ get more if you ask?
#7 Post by Aladinsaneuk » Wed May 16, 2012 10:05 pm
if it were me, i would replace the lot - new disk but secondhand / serviced caliper
bigearsbilly
#8 Post by bigearsbilly » Fri May 18, 2012 1:49 pm
hoho!
That happened to me on a Caponord a few years ago.
Quite entertaining isn't it?
Falcorob
#9 Post by Falcorob » Fri May 18, 2012 6:37 pm
He's relisted them for a once only special price of £39. Or £37 if you buy it now?? :smt003
http://www.ebay.co.uk/itm/ws/eBayISAPI. ... 1027478044
Thumper
#10 Post by Thumper » Sun May 20, 2012 4:39 pm
Almost sure to be caused by a mal adjusted rear brake lever... :smt115
Always expect the unexpected
moggyvan
#11 Post by moggyvan » Mon May 21, 2012 7:36 pm
....What Thumper said. If the rod and lever aren't adjusted correctly the brake fluid does not always return from the calliper to the master cylinder.
The same thing happened to me last sunday and I had to pull over and allow more slack in to the lever. Brake disc was a dull cherry red.........
