Decent Battery
Decent Battery
What are decent batteries for the falco and where is the bet place to buy? The falco's battery is on its last leg, and it struggling to hold its charge, and the voltage is pretty low.
Wemoto have the Yuasa for around £63 or the motobatt for around £60. Any other contenders?
Thanks,
Dale
*EDIT* The battery in my bike is a YTX12-BS, but there seem to be other part numbers such as YTX14-BS and CTX12-BS. Confused.....
Thanks,
Dale
The search function on here will reveal a wealth of info ......
Yuassa YTZ14 (I forget the suffix) is what I have - it's better than the standard YTX14BS but needs some spacers (bits of wood) as it's physically smaller.
YTZ 14S; 230 CCAD-Rider wrote:The search function on here will reveal a wealth of info ......
I have recently bought one of the yellow Motobatt batteries and i has been fine, fitted in straight out of the box and fired up as they said it would.
I paid under £50 for mine form e-bay.
http://www.ebay.co.uk/itm/270910962815? ... 1439.l2649
When I clicked on this the price has doubled, might be a mistake.
Speed Blue SL 1000 Falco
- back_marker
I've just got one, cost £45 delivered, that's from Busters evilbay shop. If you check out their spec sheets then they claim to have more Ah and CCA so better whichever way you look at it. MBTX12U is the one you want.Tonyunn wrote:I have recently bought one of the yellow Motobatt batteries and i has been fine, fitted in straight out of the box and fired up as they said it would.
If you are really stuck on a Yuasa, keep an eye out on ebay, you can generally get one for between £40 - £45
http://www.ebay.co.uk/itm/Yuasa-YTX14-B ... 3367e4324e
Edit:
Holy crap, see what you mean about the price going up on the Motobatt ones.
http://www.biker-discount.co.uk/motobat ... 2365-p.asp
- Steve McQueen
- Steve McQueen
Decided to go for one of the motobatt ones. It was £50 from amazon.
http://www.amazon.co.uk/gp/product/B004 ... 00_s00_i00
Dale
Dale
- Firestarter
- Twisted Firestarter
I've had an SVR one on for about 4 years, which has been run flat a few times (forgot to plug in the Optimate), but is still going well
But, you've already bought one so kinda moot
https://www.ridersite.com/viewtopic.ph ... ht=battery
- randomsquid
- Wear the Fox Hat
- flatlander
Any should be fine as long as its not second hand from a webfoot ;)
Give griff a ring his uprated ones are 65 QuidDalemac wrote:3 weeks have passed and still no Motobatt battery.
Apparently the courier managed to damage it![]()
and guess what- they have none left in stock! Means they are sending out a Dynavolt one instead (which is a bit extra, but I don't have to pay the difference)
Any thoughts on the Dynavolt?
Dale
