Been on one of those dyno things
wayofthedarkhand
#1 Post by wayofthedarkhand » Sat May 05, 2012 12:52 pm
Never been to one before so thought i'd be fun.
Saw some nice flames out of the exhaust coming off the throttle at full tilt.
As suspected, my Falco's poor fuel consumption is due to it over fuelling, running rich at low throttle positions, which is where it spends most of its life.
What's the cure? Power commander? Chip?
112BHP so as expected
Torque curve - 70.9ft/lbs
Just for fun, here's my old ZX9R dyno print out:
Last edited by wayofthedarkhand on Sat May 05, 2012 4:17 pm, edited 1 time in total.
Re: Been on one those dyno things
#2 Post by Kwackerz » Sat May 05, 2012 1:08 pm
wayofthedarkhand wrote:As suspected, my Falco's poor fuel consumption is due to it over fuelling, running rich at low throttle positions, which is where it spends most of its life.
Ride it with the throttle open more... :smt005
What's done to it in the way of mods? I assume it was derestricted properly and had the wire snipped?
#3 Post by Aladinsaneuk » Sat May 05, 2012 1:10 pm
iirc your bike is totally standard
i would decide what you want the bike to do - better mpg, better mid range etc
then work out what you want to enable that - i.e. exhausts, air filter etc
then get a gabro chip to suit
and seastar first saturday runs :)
wayofthedarkhand
#4 Post by wayofthedarkhand » Sat May 05, 2012 1:20 pm
Derestricted, airbox bit removed and wire snipped.
It's running Beowulf cans.
Everything else it stock.
Pretty happy with how it rides, better efficiency at low throttle levels would be nice as that's where I ride it most.
#5 Post by flatlander » Sat May 05, 2012 3:43 pm
tune up? balance exhausts etc? :smt017 if you did the air box did you remove theb trumpet bit as apparently that can help with MPG
wayofthedarkhand
#6 Post by wayofthedarkhand » Sat May 05, 2012 4:25 pm
flatlander wrote:tune up? balance exhausts etc? :smt017 if you did the air box did you remove theb trumpet bit as apparently that can help with MPG
Need to get my hands on a set of vacuum gauges.
Here is the airbox:
A new high flow filter will help lean things out a bit, but on large throttle openings the it might then become a bit too lean, not that i spend much time there. I'm usually always below 6.5k rpm unless i'm just having a bit of a hoon.
