Ghost in my machine is back
k1w1boy
#1 Post by k1w1boy » Sun Apr 22, 2012 8:20 pm
... after about 2 months of fault-free riding post big, expensive investigation/repair and went to start: fzzzt! + diag 1. At a complete loss after a few more goes (the dash returning to normal - no clock reset- after switching the ignition on and off), I armed then tripped the alarm. And it started.
Pretty bike. Sweet when it runs. Frikkin' twilight zone once and a while.
#2 Post by Aladinsaneuk » Sun Apr 22, 2012 9:15 pm
is it anti colonial?
k1w1boy
#3 Post by k1w1boy » Sat Apr 28, 2012 2:27 pm
... could external electrical interference mess up starting? I ask because this fault has only ever occurred in the same supermarket carpark. :smt017
Firestarter
Twisted Firestarter
#4 Post by Firestarter » Sat Apr 28, 2012 3:41 pm
Check the kill-switch. I'm sure mine shows Diag +1 when I press it
Firestarter
Twisted Firestarter
#5 Post by Firestarter » Sat Apr 28, 2012 3:43 pm
Saying that, it probably shows that when the power is cut to one of the circuits, i.e. the ignition circuit - which might be cut by the immobiliser on your alarm. Most probably the alarm, given that was the last thing you did, perhaps an internal relay or something is getting stuck?
k1w1boy
#6 Post by k1w1boy » Mon Apr 30, 2012 8:03 pm
.... And now here I am apparently stranded about 5miles from home, after a pig of a Monday with my zapping, non starting Falco. None of my earlier tricks have worked - confirming that I just got lucky with the post zap starts I've managed lately. RAC wants to ferry me home and try to start the thing for me in the morning. These incidences have gotten closer together - there's something seriously (or simply!) rotten here that I just don't have the mechanical aptitude to get to the bottom of. Ive had a great couple of months since the big spend fix but now I'm utterly gutted :smt019
#7 Post by Samray » Mon Apr 30, 2012 8:07 pm
Feel for you mate :smt012
but don't despair ...... yet. :smt002
#8 Post by Kwackerz » Mon Apr 30, 2012 8:12 pm
Someone has clearly replaced your Aprilia with a Ducati.
I'd be spitting feathers..
And phoning Don Plane at Southern Cross for help..
k1w1boy
#9 Post by k1w1boy » Tue May 01, 2012 4:44 am
.... Comparatively small beer in the greater scheme of things Sam. Will defo call somebody, Tim ....
....at this rate, frikkin ghostbusters
#10 Post by Falcopops » Tue May 01, 2012 7:17 am
k1w1boy wrote:... could external electrical interference mess up starting? I ask because this fault has only ever occurred in the same supermarket carpark. :smt017
Given your subsequent posts this may be a moot point, but my alarm will not disarm using hte key fob thingy when I'm close to transmission towers at the top of a couple of hill runs I frequent. I need to allow the alarm to do it's thing then manually override with the key on/off proceedure.
#11 Post by Samray » Tue May 01, 2012 7:37 am
No other eleckutrickery gadgetry about your person interferring?
or fob battery on the way out?
k1w1boy
#12 Post by k1w1boy » Tue May 01, 2012 6:00 pm
...something I didn't mention was the strong buzz and click at the starter relay(?) under the right rear bodywork. Could it be something as simple as this? The former keeper did lots of investigations into this, and Don at Southern Cross contradicted this forum by saying that the oem starter relay on the later falcos was good kit. Will push it to my local garage on the weekend and see what they say. I'm hoping it won't mysteriously start so the fault can actually be observed - the one time I did take it up to the pros in Kilburn, without the fault occurring, they couldn't tell me anything or offer a fix.
#13 Post by D-Rider » Tue May 01, 2012 7:03 pm
k1w1boy wrote: Don at Southern Cross contradicted this forum by saying that the oem starter relay on the later falcos was good kit.
Dunno what might have given him that idea - he's in a minority of one with that view.
The later Aprilia ones that you can buy now (the 150A ones) are OK.
#14 Post by fatboy » Tue May 01, 2012 7:43 pm
Early starter relays are the same as those used on 50cc Aprilia Hair Dryers
Not good kit... starter relay should click when ignition is switched on,this is normal, the circiut energising, buzzin not normal
I had Diag 1 showing, no starting ect, it turned out to be a broken wire on the ECU giving me itermittent fuel supply
Have a look at the ECU and its leads in/out
#15 Post by Kwackerz » Tue May 01, 2012 8:00 pm
Maybe thats what he's on about.
Anyhoo..
Ghostbusters:
555-2368
