oil viscosity?
Posted: Sat Apr 21, 2012 7:13 pm
10/40 or 15/50 ?
Owners handbook says 15/50 but have seen 10/40 advertised as 'suitable'
Am I better off following the book ?
Re: oil viscosity?
Posted: Sat Apr 21, 2012 7:37 pm
fatboy wrote:10/40 or 15/50 ?
Aprilia put out a service bulletin saying that if a bike suffers from clutch slip, if all the other "fixes" fail, then you should try 10/40.
15/50 is the default - that's what I use.
Posted: Sat Apr 21, 2012 9:31 pm
by anzacinexile
Close D but it was clutch drag causing finding neutral difficult.
I run 10W/40 because it did cure the finding neutral when cold problem but also I buy my oil in bulk (got 4 bikes in the garage) and I dont have to faff about with an odd can just for the Falco
Posted: Sat Apr 21, 2012 10:58 pm
Posted: Sun Apr 22, 2012 6:48 am
by joecrx
7/;47 am , just up to read first post , and its an oil thread
im away back to bed ,
not a good start to the day
Posted: Sun Apr 22, 2012 8:56 am
as it is an oil thread the key thing to also consider is full or semi synth oil
common thought is that earlier, faster falcons, black, red, blue and silver prefer semi synth oil - later two coloured bikes seem to be of with full synth oil
Posted: Sun Apr 22, 2012 9:08 am
Aladinsaneuk wrote:as it is an oil thread the key thing to also consider is full or semi synth oil
Don't the yellow ones need any oil
I thought it was only the red ones and black ones that sometimes had a problem with fully synth - though I could be wrong.
The oils Aprilia recommend are actually semi-synth anyway - though I've run mine on fully synth most of its life. Currently using semi but will probably be changing back at the next service.
Posted: Sun Apr 22, 2012 9:12 am
what yellow ones? I thought we had burned them all?
and iirc some one with a blue one did try full synth and it was not a good idea....
