Opened my petrol cap at the filling station and a load of water poured in that was sitting there ?//
Is there ment to be a drain ?
Thanks Keith
Petrol cap
- Falcopops
there is a drain hole, but the ally nipple at the bottom of the tank is normally the culprit and gets blocked, you're not the 1st.
I took mine off and opened it up a bit with some small drills untill I was happy that it wouldn;t block again, I can;t remember how big I went 5 or 8 mm, but if you do it make your own call.
Never blocked since though.
