Firestorm stand pics??
Posted: Tue Feb 21, 2012 2:08 pm
by furygan man
Has anyone got pics of firestorm stands fitted to a Falco, side and rear views so i can compare stand down position and lean angle. Had mine fitted a few weeks ago and it looks like the lean is way too much, Griff assures me it's fine...I'm not sure
Will put up pics of the bike but maybe a week or two before i'm back down again
Ta
Posted: Tue Feb 21, 2012 2:31 pm
by Tonyunn
Not sure if this shows you enough but I have the firestorm stand fitted.
It made a hell of a difference for me, I was terrified that the original stand was going to topple, the new one is excellent.
I have to keep the bike almost straight to get the stand down.
Posted: Tue Feb 21, 2012 2:34 pm
by furygan man
Tonyunn wrote:Not sure if this shows you enough but I have the firestorm stand fitted.
...that was quick...any chance of a larger pic so i can crop the top parellel to the ground to gauge the lean angle better, do you have a side view showing where the down postion is
I do appreciate your help
cheers
Posted: Tue Feb 21, 2012 2:38 pm
by Tonyunn
Is this any good, don't have a side view.
Posted: Tue Feb 21, 2012 2:41 pm
by furygan man
...thanks, I'm sure mine leans over a lot more than that, obviously be better when i post my own pics for everyone to comment
Posted: Tue Feb 21, 2012 2:42 pm
by Tonyunn
One thing to watch for is the spigot for putting the stand down it is quite small and you really need to make it longer, I did this by getting a box\tube spanner and cutting a slot into one end and forcing it over the spigot, like a sleeve if you see what I mean, I then filled it with chemical metal painted it black and now I can put the stand down while sitting on the bike.
Posted: Tue Feb 21, 2012 2:44 pm
by furygan man
Tonyunn wrote:One thing to watch for is the spigot for putting the stand down it is quite small and you really need to make it longer, I did this by getting a box\tube spanner and cutting a slot into one end and forcing it over the spigot, like a sleeve if you see what I mean, I then filled it with chemical metal painted it black and now I can put the stand down while sitting on the bike.
Sorry not sure what a 'spigot' is but have no probs with the stand going down, they did assure me the original Falco plate remained on!
Posted: Tue Feb 21, 2012 2:50 pm
by Tonyunn
The bit that comes off the main support atand to enable you to put the stand down.
Here is an earlier picture with the original stand.
You can see there is more of an angle, and yes the plate stays on the bike, all I had to do was sort out a new hole for the electrics.
Posted: Tue Feb 21, 2012 2:55 pm
by furygan man
mine definately leans over more now than on the original stand!!
Posted: Tue Feb 21, 2012 2:59 pm
by Tonyunn
I will try and get more details for you on Thursday evening, I can get the bike out and photograph it and get some measurments for you.
Posted: Tue Feb 21, 2012 3:21 pm
by furygan man
...that's good of you, will try and get some photo's of mine posted on Mon, have got some on my phone but they don't really show the lean
Posted: Tue Feb 21, 2012 3:51 pm
by Falco668
I recently "bolted on" a 99 firestorm stand, as above just drilled a new hole for the switch operating dowel. It was a straight off/on job after that, now the bike leans over slightly less than with the original BUT the angle of the base is far more square with the ground and the whole thing feels far more stable. I used to carry a piece of ally, about 2" square to sit under the original stand, not the most confidence inspiring of fixes!!!!. Hope you get the angle you are after.
Posted: Tue Feb 21, 2012 7:21 pm
by Tonyunn
Furgyman I can't get the bike out but here are a couple of pics of my "Firestorm" stand.
Posted: Tue Feb 21, 2012 8:16 pm
by Falconihlist
I did notice a difference in lean when I fitted the ohlins shock, it leaned more, but still stabe on a blade stand.
Posted: Tue Feb 21, 2012 8:19 pm
by Chabby
When I fitted the Firestorm stand I thought it was leaning too much.
I followed the advice of someone on here and had a blob of weld put on the 'stop' where the stand touches at the top when in the down position.
It was only a small amount (about 1/4") but it made all the difference. Now more upright and puts less stress on the stand.
