Electrical Woes (headlight & rear indicator)
I was giving the bike a once over before taking it for a quick blap and I had noticed the RH rear indicator wouldnt flash (the fronts work fine- I have RSV mirrors and LED indicators on the side fairings) The bulb was checked and its fine (swapped to the LH to validate)
I was intending to go to the servo to check the tyre pressures and fill up with fuel and since I live within a few kays of the servo I took my chances without the RH rear indicator as its mainly straight road to the servo & it was around 7pm and traffic was extremely light.
On the way home I noticed the headlight and dashboard lights were continuously cutting in & out, but the indicators were still functioning fine. I thought to myself straight away that may be a loose earth terminal, but it is securely fastened...
So does anyone have an idea as to what could be causing this?
- Falconihlist
As Blinkey says. I had an indicator problem at the rear, and it turned ot to be where the connector goes into the harness in the tail pod. I stripped it down and put some new wire in, problem solved. As for the headlight though, that will take a bit more investigating / imagineering
Black is fastest!
re headlight and dash light. There is a connection within the wiring coming from the l/h switch gear where one green wire connects to 4/5 green wires and that connection (crimped) may well have stretched and be coming loose. The connection is about 8/12 inches away from the l/h switch gear.
With the ignition on and the light switch on, slowly squeeze / manipulate this wire working along the whole length to see if you can knock the lights on and off. If you can, then its time to get the soldering iron out!
They can chafe a bit around the headstock.
Not sure if any of the wires in that area are ones in the circuits you are having issues with.
A few years back I spotted some of my wires in that area about to go and I was able to re-insulate and protect them before they caused a problem. Guess I was lucky I had the right fairings off at the time.
Cheers, you must have posted that reply up just as I was responding to previous comments.davidm wrote:See my post above. Bar risers will stretch the wires coming from the L/H switchgear and the connection in that loom powers headlight, dash light, tail light etc.
That definitely sounds like the culprit!
- randomsquid
- Wear the Fox Hat
Re: Scary
Quite. The lengths some people will go to, to avoid buying an Abba stand...greybika wrote:![]()
Those are the scariest photo's I think I've ever seen! Especially the middle one
Re: Scary
Unfortunately abba stands aren't available down under, but us colonials like to think we are much more creative & love a challenge much more then you whinging pommy folk!mangocrazy wrote:Quite. The lengths some people will go to, to avoid buying an Abba stand...greybika wrote:![]()
I have had her together since Oct last year here is my ridersite intro thread with pics:blinkey501 wrote:Looking at what wheels you have and the front end you have put in this is going to be a very nice falco
https://www.ridersite.com/viewtopic.ph ... highlight=
Well I have nooj's old 100mm Gilles riser setup, I'm having dramas with the levers clashing etc so I have ordered a set of 60mm risers. This shall give me more clearance and then hopefully will also adress this electrical issue I'm having also!
