Blue spring shock
Posted: Sat Jan 21, 2012 1:56 pm
by wayofthedarkhand
Does the shock or the bike have a ride height adjustment at all?
I'm not finding the shock too bad at the moment, but reckon the bike could do with being about 10mm higher at the rear.
Posted: Sat Jan 21, 2012 2:06 pm
No - one of its many shortcomings ...
Posted: Sat Jan 21, 2012 2:55 pm
Yes, Falco shock length (eye to eye) is 317mm. This makes the bike comparatively low at the back and slow-steering. An Ohlins for 1st and 2nd Gen Miiles is 320 or 321mm long (depending on model) and can be adjusted up to 326/327mm length. This gives a maximum of an extra 10mm shock length available, which translates to 3-4 times that amount at the back wheel, depending on linkages. That really should be enough for anyone unless the bike is being used exclusively on the track.
By the sound of it, a Mille Ohlins on its default setting would suit you perfectly. If you want to see what models to go for, follow this link:
https://www.ridersite.com/viewtopic.php?t=9153
Posted: Sat Jan 21, 2012 3:51 pm
I do have a feeling of deja vu Carl.....
Posted: Sat Jan 21, 2012 6:01 pm
by wayofthedarkhand
Just thought i'd ask, as some bikes (not shocks) have a ride height adjustment.
Posted: Sat Jan 21, 2012 6:44 pm
I was teasing ;)
Posted: Sat Jan 21, 2012 8:38 pm
wayofthedarkhand wrote:Just thought i'd ask, as some bikes (not shocks) have a ride height adjustment.
Yes, I remember the old ZXR750 Kwaks used to have a very easy to use ride height adjuster on the rear shock mounting.
Posted: Sat Jan 21, 2012 9:07 pm
by anzacinexile
mangocrazy wrote:By the sound of it, a Mille Ohlins on its default setting would suit you perfectly.
Thats what I have apart from my forks are dropped by 6 lines to allow the fitting of the clip-ons over the triple. About as extreme as you would want to go as mine used to gently shake the bars occasionally until I fitted an Ohlins steering damper
Posted: Sat Jan 21, 2012 9:12 pm
6 lines!
I did mine with three....
Posted: Sun Jan 22, 2012 1:28 am
Aladinsaneuk wrote:6 lines!
....... and I thought you got staff discount on "medicines" .........
