dave
falco fit ohlins rearmangocrazy wrote:Hi Dave. OK - time for 20 questions...
What shock do you have?
How many miles do the shock and forks have on them?
Has the oil ever been changed in the forks?
What brake hoses do you have on the bike?
What pads are fitted and how much meat is there left on them?
How much money do you have to spend?
well ,,its not a problem, i'm just curious to find out how DEEP the water is.Aladinsaneuk wrote:Wait till new year to sort it mate
Most Places are closed till then
well that's the snag !! most here say brakes are good, i met griff at the nec, he said they should be ok... ive striped and cleaned calipers, hell lines ,cleaned discs buttons etc no, you can stop it but its not inspirationalD-Rider wrote:I've changed to a Brembo racing radial master cylinder, Hel lines and 4-pad callipers. They improved things a little bit but not hugely. The standard setup is pretty damned good.
Mine lost a bit of feel over time but after cleaning the calliper pistons properly and changing the fluid, they were pretty top-notch again. I think the fact I'd recently serviced them is probably why the 4-pad / radial M/C setup wasn't the big improvement that some others have reported. I think a lot of them may have compared a crudded up old system with a nice clean upgrade.
well yes they have radials , BUT Ive ridden lots of others that aren't and most (not all) are better than Ive got . i'm intrigued by your comment (OE removed to fit PFM rotors) looked at web site shows ,rotors carriers and a clip , can PFM be fitted to my existing carriers ? (that would cut down cost)mangocrazy wrote:I'm guessing the 2009 Brutale (and possibly the 2005 Speed Triple) both had radial calipers? They do tend to give a more aggressive and stronger feel. Unless you're prepared to spend a LOT of money on forks with radial brake fitments, and radial calipers to suit, then I doubt you'll ever quite get to those levels with the Falco.
It might be an idea to get the rotors skimmed and start afresh with a new set of pads. That way you're removing all the old pad crap and getting down to new metal.
Alternatively if you're interested I've got a pair of stainless OE rotors (no carriers or buttons) that I removed to fit a set of PFM rotors. They've only done running-in mileage (about 500 miles) and still have the cross-hatching marks on them. They're doing nothing in my attic and they're yours for £50 plus postage if you're interested.
