Rear brake line fitment
Posted: Fri Dec 16, 2011 9:12 am
by Tonyunn
I intend to change the brake lines so I have bought a Venhill rear set up.
Apart from the usual bleeding problems are there any "Falco" related problems with fitting a new line.
I don't intend to do this until the spring when I will have new pads as well.
In a way I want to check out Venhill as their product does look good, espeacially their banjo bolts which seem to allow an easier fitment.
Posted: Fri Dec 16, 2011 9:49 am
Nope, Alad is just lazy and hasnt cleared his inbox! :smt002
Posted: Fri Dec 16, 2011 9:53 am
Kwackerz wrote:Nope, Alad is just lazy and hasnt cleared his inbox! :smt002
I never clear my inbox - new PMs just push the old ones out of the way.
That said ....
Kwackerz wrote:Alad is just lazy
Posted: Fri Dec 16, 2011 11:02 am
i cannot help being popular - i get all sorts of questions - like where too find the best stilts, and which hair dye works on pubes... fortunately I have friends who have spent ages finding the answers to such questions so i can only share the love....
and if i was to replace a standard falco rear brake line, i would order a mille length to replace it..... just in case you fit the mille swinger :)
no specific falco issues btw - i would follow KZMilles guide in the aprilia tech section and i prefer to reverse bleed
Posted: Fri Dec 16, 2011 11:08 am
by Tonyunn
Thanks for that and I can state with utmost certainty I will not be changing the rear arm.
Posted: Fri Dec 16, 2011 11:15 am
yet.......
Posted: Fri Dec 16, 2011 11:31 am
Aladinsaneuk wrote:i
Not sure about that - the biggest difference to the rear brake line length would be due to the significantly different location of the rear master cylinder on the mille.
Certainly the Falco line works without problem if you fit a Mille swingarm - if you want to be cautious, order a line an inch longer than standard (certainly no more than that)
Posted: Fri Dec 16, 2011 7:59 pm
Tonyunn wrote:Thanks for that and I can state with utmost certainty I will not be changing the rear arm.
Sensible chap. I've had this argument many times, but the Falco frame and swingarm were designed mechanically and aesthetically to work together. Why break up a winning combination?
Posted: Thu Dec 29, 2011 1:53 pm
by Tonyunn
I got the kit and since I was bored I fitted it to the bike, the quality of the hose and fittings is fine.
One thing though is they supply a angled banjo which is a t**t to fit to the pump, so much so in fact that I have ordered anothe rstraight fitting to replace it as I think the strain on the hose will prove to be a problem later on.
As for the bleeding of the brake I tried for a while and but got no where and then I removed the caliper and held it up and then it bled perfectly and quickly.
Posted: Thu Dec 29, 2011 2:32 pm
Tonyunn wrote:As for the bleeding of the brake I tried for a while and but got no where and then I removed the caliper and held it up and then it bled perfectly and quickly.
That's the trick Tony!
Posted: Thu Dec 29, 2011 9:22 pm
I refer to my earlier answer stating to use kzmille's guide to bleeding....
It's in the aprilia tech section ...
